is 340whp reasonable?
Old 01-14-2009, 10:54 AM
scorpion_z28's Avatar
Default is 340whp reasonable?
Im asking this for a friend of mine.
His car is a 95 Camaro M6 with the following mods
cc306,ported heads & intake,shorties,58mmTB,CAI.
He dyno tuned it & the car made 340whp only
is this normal?
Thanx
Old 01-14-2009, 10:58 AM
Elliott's94Z's Avatar
I would have guessed it would have made a tad bit more...could be because of the shorty headers
Old 01-14-2009, 11:26 AM
want297z's Avatar
It's the shorties. I made 335 on a much smaller cam and no ported heads. Went to long tubes and picked up to 345.
Old 01-14-2009, 11:30 AM
LSWHO's Avatar
I woulda guessed 354.2whp.
Old 01-14-2009, 12:00 PM
ss.slp.ls1's Avatar
A lot of mods/work to bolt up some shorties...
Old 01-14-2009, 01:07 PM
How much difference will it make with LTs?.& by the way it doesn't have a cat back & no 1.6RR.
Old 01-14-2009, 01:13 PM
ss.slp.ls1's Avatar
Definitely add some LT headers, CC 1.6 Promagnum NSA rr's, TF guideplates, and a nice catback or an electric cutout before the axle.
Doing all of the above will probably net you an additional 25 rwhp!
Old 01-14-2009, 01:40 PM
[QUOTE=ss.slp.ls1;10846654]Definitely add some LT headers, CC 1.6 Promagnum NSA rr's, TF guideplates, and a nice catback or an electric cutout before the axle.
Doing all of the above will probably net you an additional 25 rwhp![
Wow 25 more whp for just doing that? what else do you suggest to get more HP out of this thing?
Old 01-14-2009, 01:42 PM
ss.slp.ls1's Avatar
[QUOTE=scorpion_z28;10846835]
I wouldn't say "just" that, those are some major changes. But yes, I would think you have a lot left on the table with your current set up.
Old 01-14-2009, 01:58 PM
[QUOTE=ss.slp.ls1;10846855]
Cool my friend is already looking for LTs & RR now.
What else should i advice him to get? his goal is 380-400 whp N/A
Old 01-14-2009, 02:11 PM
ss.slp.ls1's Avatar
[QUOTE=scorpion_z28;10846950]
He'll need the guideplates to run the NSA rr's.
Easiest way to top 400 would be to throw a 50+ shot to it.
If not, $$$ comes into play...better heads.
Old 01-14-2009, 02:27 PM
I8ASaleen's Avatar
Better porting, an electric waterpump, Longtubes, 1.6RR's, and better springs. I'm really surprised that he got the heads and cam done, yet didn't do all the important stuff when the heads are off like bigger valves/1.6RR's/hardened pushrods/LS7 lifters/and beehive springs.
Old 01-14-2009, 02:34 PM
yea he bought them from a local shop & just slamed them on with only springs no RR or other valve train parts.
Im really surprised of the result i've seen only Cam LT1s here with better numbers.
Old 01-14-2009, 02:37 PM
ss.slp.ls1's Avatar
340 is nothing to snuff at for a cam-only LT1, that is a good number, just not with that cam. It need to be done right.
Old 01-14-2009, 02:53 PM
I8ASaleen's Avatar
^Truth.
Old 01-14-2009, 03:18 PM
slick1851's Avatar
is this normal?
Thanx
You own that car in your sig?
Old 01-14-2009, 03:33 PM
phirepower's Avatar
The problem is more than likely that cam. Even with head work it is absolutely enormous on stock heads, even after some port work. Extensive port work is required. Your 58mm throttle body isn't giving you a gain. And I would not finger out the shorties as your primary concern. I would estimate something is not functioning properly, or your tune is not a good one. Some of the others are suggesting to do more bolt on's, i would hold off until you figure out your current issue(s). your car should be making more, no one can argue that...
Old 01-14-2009, 03:36 PM
nik1703's Avatar
How do i tell if i have LT headers or shorties?
Old 01-14-2009, 03:39 PM
yes thats my car stock M6
Old 01-14-2009, 03:41 PM
What kind of problems should he look into?
the engine was recently built.
Quick Reply: is 340whp reasonable?
