Trickflow guideplates causing my pushrods to not be straight?
As suggested, get the ISKY "adjustable" ones. Leave rocker studs lose enough to slide them so the RR tip is CENTER on the valve stem then tighten the rocker studs. You "may" have to grind the ISKY ones or spread them apart.
The GM guide plates I did have were not "hardened" and did wear from the hardened push rods. The GM ones are one piece and like all one piece guide plates do not allow single RR adjustment from side to side.
After the ISKY's are installed you can tack weld them togeather...but I did not and they have been stable for years.
