Removing oil pan out of car.
Old 01-20-2009, 04:16 PM
I8ASaleen's Avatar
Default Removing oil pan out of car.
Yep I'm full of projects. I have all of the bolts off of the stock pan and I'm trying to drop it, I've jacked the engine up about 3-4 inches and it still doesn't want to come out - seems like its hitting against the bellhousing and the engine doesn't want to go any higher. Any input would be great, I have the starter out and hooker LT's are in place w/o the y-pipe and away from the pan.
Old 01-20-2009, 04:21 PM
juanito's Avatar
did you get the corner studs by the rear main seal??
Old 01-20-2009, 04:34 PM
I8ASaleen's Avatar
Yep, I got the nuts off of those. Its completely loose, it just won't come completely out b/c it won't get under the bellhousing. I'm thinking I might have to move the passenger side header a bit and maybe slip it out sideways.
Old 01-20-2009, 05:15 PM
shbox's Avatar
You removed the oil level sensor, yes? Seems I have heard manual transmission cars need the trans/bell housing removed, but not sure.
Old 01-20-2009, 05:23 PM
1redta's Avatar
Default re
loosen the k-member bolts. just one at a time, take the bolt out and put it back in with 2-3 threads hand tight. you should have enough wiggle room then, the oil sensor has gotten me before, but shoebox already covered that one. Good Luck
Old 01-20-2009, 05:38 PM
I8ASaleen's Avatar
Oil level sensor is out and off to the side, if I loosen the k-member bolts will the car still be steady b/c it's up on the lower A-arm right now.
Old 01-20-2009, 05:57 PM
1redta's Avatar
Default re
No, you need to put your jacks to the rear of the front subframe or better yet on subframe connecters if you have any.
Old 01-21-2009, 06:02 PM
I8ASaleen's Avatar
Anyone gotten theirs off w/o removing the k-member bolts? Or has anyone had to drop the transmission? Just trying to get some more input here b/c I have to take it out now b/c chunks of the old gasket are now inside of the pan.
Old 01-21-2009, 06:32 PM
ElkySS's Avatar
its not hard to lower the k-member. iv done it. just take one all the way out, then put it back in about 3-4 threads, then repeat with the rest.
Old 01-21-2009, 06:58 PM
I8ASaleen's Avatar
Alright, gotta get the timing chain on first. Then I'll finish the oil pan and get everything back together.
Old 01-21-2009, 07:47 PM
1slo_camaro's Avatar
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
i have put i have a A4. i popped the intake and was able to lift the motor up high enough to pull the pan out. again to second the oil level sender. other then that just make sure everything is unbolted.
Old 01-21-2009, 08:44 PM
blkm6formula's Avatar
on an m6 car you have to lower the K member or remove bellhousing (k member is ALOT easier!) with an a4 car you just have to jack up the engine, the k member and intake can remain in place!
Old 01-21-2009, 10:43 PM
I8ASaleen's Avatar
That's Gay...
Old 01-22-2009, 07:50 AM
leadfoot4's Avatar
OK, I've done this a couple of times, but I have an automatic tranny, as someone already said. I did not, however, have to remove the intake fo extra room, but I suppose that might work if you have a 6 speed.
Nonetheless, getting the oil level sensor out of the pan is important (that caught me the first time), as well as having the crank rotated properly, so the counterweights at the front of the engine are "up" and out of the way.
Quick Reply: Removing oil pan out of car.
