LT1 facts needed
Old 01-20-2009, 08:44 PM
Kmaroman's Avatar
Default LT1 facts needed
I'm not an expert, but want to know alot of stuff about lt1s. So the next time my doumass friends starts pull **** outta his ***, I can throw facts in his face. What all is different from an LT1 block an SBC? Throw it all at me cause next time he runs his mouth I'm gonna tell him to the lay the money an looks up this webpage!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-20-2009, 09:00 PM
joelster's Avatar
Block differences--different front timing cover, different water pump. Slightly different cooling passages due to reverse cooling. Gear driver water pump, gear assembly in the lifter valley towards the front of the block.
Similarities--they can take the same crank (1-piece rear seal), rods, pistons, oil pump, oil pan, bearings, main caps, lifters.
Old 01-20-2009, 09:05 PM
Kmaroman's Avatar
sweet now I'm going to burn his ***
Old 01-20-2009, 09:14 PM
SoxXpupPeT's Avatar
dont forget the opti spark!
Old 01-20-2009, 09:17 PM
MTBSully's Avatar
arent you going to seem like a know it all now?
i think it would just be funnier to let him continue to think that he is right and just laugh at him whenever he says an inncorrect fact
Old 01-20-2009, 09:20 PM
Kmaroman's Avatar
No dude he won't leave me the **** alone, its getting on my nerves. I dont try to act like a know it all cause I'm actually getting facts an such when he drops the bullshit, I'll make him look bad an maybe he will ifnally leave me be
Old 01-20-2009, 09:22 PM
z28rob18's Avatar
dont just be like dude remember wat u said yesterday well your wrong because. . . .
if you do that then you'll look lik a know nothing when you show him this cuz those kinda ppl usually feel stupid and will make fun of you for not knowing everything to begin wit.
Old 01-20-2009, 09:34 PM
phantomzer0's Avatar
ltxtech.com
Old 01-21-2009, 09:18 AM
Kmaroman's Avatar
NO everytime he comes around me this is all i here, he tell's me this everytime i see him. Dude your 350 block is no different then an ls or SBC, i said dude there's alot different reverse flow cooling the distributor. I'm just going in depth on what's all different now. I'm not going to bring it up unless he says something about it. Your heads will work on any 350 i said, AH NO they won't, dude there's nothing different.
Old 01-21-2009, 10:14 AM
ss.slp.ls1's Avatar
https://ls1tech.com/forums/lt1-lt4-m...ewbie-faq.html
This should help you burn his ***.
Old 01-21-2009, 10:35 AM
z_speedfreak's Avatar
everyone always overlooks the stickies. i wonder if its because of the yellow background..
Old 01-21-2009, 10:44 AM
myltwon's Avatar
LT1 is iron block, LS1 is aluminum block
LS1 is a sleeved block
etc etc, many more but you get the point
Old 01-21-2009, 10:53 AM
the_merv's Avatar
LSX has Lifters under the Heads..
LSX has 6-Bolt Mains..
LSX Crank is recessed into the Block more..
There are more, I would kick that guy in the nuts and go about my day.
Old 01-21-2009, 12:19 PM
ss.slp.ls1's Avatar
He said differences between SBC's and LT1's, never mentioned LSx. And LS1's are have cast-in liners, I don't know if it's considered a sleeved block, maybe.
Old 01-21-2009, 12:44 PM
myltwon's Avatar
yes he did
Old 01-21-2009, 12:56 PM
the_merv's Avatar
Old 01-21-2009, 02:26 PM
ss.slp.ls1's Avatar
yes he did
I was referring to the original post, my bad.
Old 01-21-2009, 02:54 PM
1994Z28Lt1's Avatar
while a sbc (1 piece rear main) crank will physically work in a lt1 dont try it with stock pistons, lt1 pistons, because they are short skirt design the rotating assembly wont be balanced properly without machine work
lt1 uses a dry intake manifold (no coolant crossovers)
Old 01-22-2009, 06:17 PM
Phnx1's Avatar
hi all, i bookmarked this corvette forum write up on the LT1 reverse cooling awhile back, still think it's a good read http://www.corvetteactioncenter.com/...ifference.html
Old 01-22-2009, 07:51 PM
Formula350's Avatar
You can technically run a SBC cam in an LT1 and vice versa. Just need to make sure you run the proper lifters. AND, a more important bit, the dowel pin in a LT1 cam is longer. So if you put it in a SBC then you'll have to either pound it in some or cut it shorter. If you use a SBC cam in an LT1 you have to put a longer one in it.
LT1s are, as mentioned, internally balanced. LT1, LT4 and L99 are all the same block. LT5 on the other hand is like no other SBC, but there are a few similarities between it and other GM motors. Corvettes have 4bolt mains, LT1s in F/B/D Body motors were 2bolt main. F/Y Body got Aluminum heads and were 350ci, B-Body were cast iron and were EITHER 350ci or 265ci (L99 4.3L V8), and I believe that D Body's were only 350ci but someone confirm that please.
92-93 were Batch Fire Injection LT1s with ECMs, 92 was only in Vettes and 93 was only in F-Body (as I believe 93 Vettes got PCMs then). They also had the 700R4/4L60, but that's not really LT1 info. The 92-93 had slightly different intakes and fuel rails, and you can't swap a 92-93 intake onto a latter year, but you can swap a later year onto a 92-93 If you want to swap the earlier onto the later, you'll need to get the fuel rails too. 93 F's (unsure on Vettes) got 22# injectors. 94-97 had Sequential Fire Injection, PCMs instead of ECMs and 24# injectors. 94+ throttle bodies don't have the Kick-down (detent) cable provisions since the 94+ used the electronic transmission (4L60E). Vettes fuel rails are also (apparently) fed on the opposite side of all the other LTx equipped cars. 95 saw the introduction of OBDII and vented Optis, B-Body cars got the vented in 94 (not sure on Vettes). The vented Opti had a small change in the way it connects to the cam, where as 92-94 had a splined shaft. 95 also saw introduction of the crank sensor. If you want to run a vented opti (whole unit) you'll need to get the timing cover from a motor from those years.
That's about all I can think of.
Here's a good bit of info on the differences of the L99 and LT1
http://www.9c1.com/technical/LT1_rebuild/ar99928.htm
Quick Reply: LT1 facts needed
