Any tips to help pass emissions?
Old 01-24-2009, 09:02 PM
sprayed5oh's Avatar
Default Any tips to help pass emissions?
I took a MD state emission's test today on my 95 Z28 and failed.So does anyone know how i can get this thing to pass?Also tried GTP stuff the goes in the gas tank.
Test results
Allowed/results
(HC) 220PPM/427PPM
(CO) 1.20PCT/3.00PCT
mods:
Hotcam
Mildly ported heads w/ 2.00 & 1.56 valves
Comp cams 1.6 Pro Magnum rr's
Edlebrock/BBK TB
GMS maf
SLP cold air kit
Kooks stainless1 3/4 full length emissions headers
Kooks stainless catted Y pipe
Borla adjustable cat back.
AC delete pulley
LT4 knock module
Tuned with LT1 Edit software by the original owner,i only have the AKM cable.
Old 01-24-2009, 09:13 PM
Black94Z28's Avatar
move to illinois where your are exempt pre 96 or 97 i believe once i found that out, i had the emission/smog stuff off within hours :chug i believe here they just check to see that there are no trouble codes and u are good to go. doesnt look like thats the case there. im not sure how much you can mess around with the tuning to get it into the range u need it
Old 01-24-2009, 09:30 PM
ebonicrobot's Avatar
Have you tried seafoam? It works really good.
Old 01-24-2009, 09:47 PM
sprayed5oh's Avatar
Not yet but i might try some.I forgot to add that it was a tail pipe test.
Quick Reply: Any tips to help pass emissions?
