Starter Relay
Old 01-26-2009, 10:32 AM
the_merv's Avatar
Default Starter Relay
As much as I've torn my car apart, I've seen the wiring go to it on the passengers side, but I've never actually found it.
I've tried searching online already and came up with notta..
Does someone have a picture they can post of where this thing actually is and what it looks like?
Thanks.
Merv
Old 01-26-2009, 11:22 AM
the_merv's Avatar
Well I was wrong on the name for this..it's the Theft Deterrent Relay..Shbox gave me that info through an e-mail..he sent a pic aswell but it didn't come through.
Anyone have a pic of this?
Old 01-26-2009, 11:46 AM
the_merv's Avatar
I got it, Shbox e-mailed the pic to me. That thing is kinda hidden..lol
Here is the pic if anyone needs it..
Old 01-26-2009, 12:33 PM
3rdgen92maro's Avatar
hmm i just tore all the HVAC and airbags out of my car and cant seem to remember if i pluged that damn thing back in. Is that relay attached to the dash?
thanks
Old 01-26-2009, 12:37 PM
robsquikz28's Avatar
if you open up ur glovebox and flip it down its on your right side behind hidden on the metal plate on the right side.....purple wires are going towards it.......
Old 01-26-2009, 12:40 PM
thanks ill have to check it out and make sure i plugged that sucker back in.
Merv sry for the
Old 01-26-2009, 12:58 PM
the_merv's Avatar
It's cool.
What it controls is the VATS..I have the VATS disabled, so I'm re-wiring that Relay to be part of the Neutral Safety Circuit for my T56 Swap, it will be controlled by the Switch on the Clutch Petal.
Old 01-26-2009, 02:14 PM
shbox's Avatar
The pic is courtesy of Brent Franker-long time supporter of the f-body community.
Old 08-03-2009, 10:33 AM
the_merv's Avatar
Very good pic.
I ripped that out and re-ran the wiring that went to it. Basically I just connected the Starter Signal Wire to the Ignition Switch..they are the wires that are on Pin #30 and #87.
For my car it was the purple wire going to the Harness C-210 Connector and a yellow wire that came from under the dash eventually back to the Ignition Switch in the start position. There was another 12ga wire on that Relay, that was the ground so don't get it confused.
Quick Reply: Starter Relay
