Cap and rotor question
Maybe, but I doubt it. Just get the MSD if you want one with pre-made line fittings. I'd find a spot you can drill a hole at and glue in a plastic vacuum barb. Alone with siliconing the bottom of the cap to extra insurance.
are you talking about the opti shbox? the cap and rotor i want to put on my 96 is off a 94 wanting to make sure it will work and that they are the same. im not using his opti because mine is still good. i just broke my rotor. so is cap and rotor the same?
You asked about cap and rotor only. That is what I replied to. If you use the old cap, you won't have a vented system. IMO, don't.
Yes (but you don't plug the holes). http://www.corvettefever.com/howto/16758/index.html
I did mine when I did the 383 build.
yea my bad. i talked to a buddy that im getting it from and he also said it was vented . thanks for the info man.
