Valvetrain Setup - What do you think?
Old 02-03-2009, 11:47 AM
ThreeHonks's Avatar
Default Valvetrain Setup - What do you think?
ok, i want to run 1.6 roller rockers, but im trying to be as cost effective about this... What do you think about using springs that come in the LT4 hotcam kit and reuse all the stock components that are currently on my 50,000 mile LT1 (locks, retainers, keepers). I will be going with non self aligning rockers so I will be getting hardened pushrods, and guideplates. I will also get new valve stem seals and be reusing the stock 3/8" studs (i believe that is the corect size). What do you think of this setup?
Old 02-03-2009, 12:04 PM
SprayedLT1's Avatar
What else are you doing besides the rockers? A cam?
Old 02-03-2009, 12:12 PM
ss.slp.ls1's Avatar
Sounds good so far, I would strongly recommend getting ARP 7/16" rocker arm studs, I think they are only $40. Then all you have to do is order 7/16" 1.6 rr's instead of 3/8" 1.6 rr's. I hope you are getting full roller rockers and not roller tip rockers. The LT4 springs will work fine for a roller rocker only install, once you slide a cam in it, you'll have to upgrade. I was under the impression that LT4 springs had retainers different from stock, but I'm not sure. Good luck with the install.
Old 02-03-2009, 12:52 PM
1989GTA's Avatar
X2 on the 7/16" rocker arms studs and rocker arms.
Old 02-03-2009, 02:36 PM
ThreeHonks's Avatar
Im just going to go with the full roller rockers for now until I can do a cam swap, etc. next winter. I figure that if I have roller rockers now, I can just reuse them once I put a cam in. I'm just using the LT4 springs for the rockers only and STOCK cam. Can anyone else confirm if stock retainers and locks will work with the LT4 springs?
Old 02-03-2009, 03:26 PM
RamAir95TA's Avatar
Pretty sure stock retainers and locks will work with the LT4 springs.
x2 on the 7/16" studs as well. Cheap insurance. Not to mention you have to remove the rocker stud to install the guideplate anyway.
Old 02-03-2009, 04:05 PM
joelster's Avatar
Yes they will work. I did the exact same thing when I first got my car. Not sure why you went with non-sa rockers though. You could have went sa and then not needed guideplates/pushrods. The springs are good to .525" lift and you won't be anywhere near that with the stock cam. I got new locks though, they are really dirt cheap anywhere you look. I can't remember if my LT4 springs came with retainers or not, I am thinking that they did. It was a while ago.
Old 02-03-2009, 04:15 PM
ss.slp.ls1's Avatar
He said he is going to cam it later, then he can simply just reuse the rockers, pushrods, and guide plates for any cam. And regardless of what cam you have, it can't hurt anything to have the most stable set up as possible, which is Non-SA.
Old 02-03-2009, 04:18 PM
joelster's Avatar
I didn't see his second post, my bad. I thought he wanted to do this as cheap as possible.
Old 02-03-2009, 04:20 PM
ss.slp.ls1's Avatar
He said it in the post you quoted, lol.
Old 02-03-2009, 05:17 PM
joelster's Avatar
Oh geez, i'm a tard today, I honestly didn't read it, just the first one.
Old 02-03-2009, 06:12 PM
ThreeHonks's Avatar
haha so it looks like im going to be doing the 7/16" studs as well since I can just reuse all this once I do cam and rework the heads next winter. Anybody have a set of used roller rockers on here? I want 7/16" stud non self aligning, and would like to either go with pro mags or crane golds. Any other suggestions on what rockers to use?
Old 02-04-2009, 12:42 AM
ss.slp.ls1's Avatar
Nope, you're spot on.
Old 02-05-2009, 10:30 AM
ThreeHonks's Avatar
https://ls1tech.com/forums/parts-wan...l#post10992409
Looking for a few things let me know what you have
Old 02-17-2009, 10:14 PM
ThreeHonks's Avatar
OK what do you guys think of this set of springs and components I found on Summit. How do they compare to the LT4 valve springs? Stronger? Weaker? Will they even work with a stock LT1 without any machining? Thanks!!
http://store.summitracing.com/partde...5&autoview=sku
Old 02-19-2009, 03:02 PM
ThreeHonks's Avatar
anyone??
Old 02-19-2009, 03:11 PM
ss.slp.ls1's Avatar
anyone??
Why not go with tried and true components?
Old 02-19-2009, 04:09 PM
LM97Z's Avatar
What is the seat pressure on them, i think thats a hell of a deal, & most all summit stuff is made by a reputable builder, but boxed for them, i wouldn't sweat them as being so-so, i'll almost garuantee those are comp/crane springs, just in a summit box, i'm glad you listed them because i'm in the market for a spring kit, & those look like they'll foot the bill, i say get them, just find out the seat pressure & the installed height. I'd say if there around 125 @ 1.80, with 358 open, that should be a good spring. I would buy them for that price.
Old 02-19-2009, 06:41 PM
ThreeHonks's Avatar
they are 125lbs. at 1.75" installed height it says if you hit applications on the link
Old 02-19-2009, 06:42 PM
ThreeHonks's Avatar
http://store.summitracing.com/partde...497+4294863036
Quick Reply: Valvetrain Setup - What do you think?
