True duals: pros and cons ?
Old 02-05-2009, 03:53 PM
SHDY 5.7's Avatar
Default True duals: pros and cons ?
Ok,this is my last noob thread I swear lol. Im putting pacesetter lt's on my car,and im contimplating buying a couple bullet mufflers and running true duals dumped off. Any power gain/loss? I do spray the car,if that helps. It spends more time on a trailer going to and from the track so noise aint an issue. Let me know. Thanks for reading, Dale.
Old 02-05-2009, 04:08 PM
ss.slp.ls1's Avatar
The only thing that could be considered a con might be that you might get bored of the sound one day, either the note or level. But that only happens to a few people, everything else is plus.
Old 02-05-2009, 04:11 PM
Hot94Z28's Avatar
Saves weight, sounds good. The only con is like stated above could get old on a DD, but I like it.
Old 02-05-2009, 04:13 PM
SHDY 5.7's Avatar
Sweet. Some people say there is some clearence issues but that's the only down side I've heard. I think it will sound pretty good,it'll probably scare everyone off but o-well.
Old 02-05-2009, 04:18 PM
CamaroRacing12's Avatar
go for it... only clearence issues r if ur going over nasty speedbumps but how often does that happen?.... i would do it if i were u... nothing like duals
Old 02-05-2009, 04:19 PM
96lt1m6's Avatar
LOL i like your introduction statement.
I encourage anyone to ask as many questions as possible knowledge is power. while there are people that will be unkind in ways there are always others that will help.
i have had true duals on my car for a while now...when i had the duals done with the stock 3.42s i did feel some bottom end power loss,the power i used to feel was moved up higher in the RPM. according to my 1/4mi. time, i did gain after the 1/8 the cure was the 4.10s.....
some will say duals are not needed but i think that all F-body cars should have come from the factory with them, judging from SEMA show GM feels the same way the new camaro has duals
Old 02-05-2009, 04:27 PM
StealthFormula's Avatar
For me my 2.5" TD's have better ground clearance than my Jet-Hot Y into Magnaflow believe it or not, only very low point are the turndowns but I have yet to scrape anything. After going TD's I will never go back...
Pros:
IMO Dumped with turndowns looks badass
Less weight
Sounds alot better
More power and wont be a restriction like a 3" Catback will be the more you mod the car.
Cheaper than a Y-Pipe and Catback setup.
Cons:
Its very loud (if dumped) so not recommended for a DD.
For your situation I would say TD's would be a no brainer and I'm sure you would love them!
Old 02-05-2009, 04:34 PM
96lt1m6's Avatar
here's mine PS longtubes,2.5" X-pipe under axle to 1 ch. flows and 3" tails
Old 02-05-2009, 04:37 PM
SHDY 5.7's Avatar
What size pipe do u guys think I should run off the header and into the bullets? Loud is good in my book,but don't want it to flow to much and hurt my performance.
Old 02-05-2009, 04:40 PM
96lt1m6's Avatar
2.5" is more than adequate,do yourself a favor be sure you do an X-pipe
some will say 3'' but depending on your mod level cam heads etc.
Old 02-05-2009, 04:43 PM
SHDY 5.7's Avatar
Wow,that looks damn good. I've had a few people tell me to go 3" w/3" bullets.
Old 02-05-2009, 04:47 PM
SHDY 5.7's Avatar
No cam or heads yet. So why do u say run an x? I was just gonna run straight pipe to the bullets,no x or h pipe.
Old 02-05-2009, 04:50 PM
An X or H will sound alot better than just straight pipes. For your setup 2.5" would be fine, 3" may even be overkill but it will be perfect down the road if your stroked out with heads/cam etc so something to consider. I went with 2.5" personally because of clearance with my lowered car.
Old 02-05-2009, 04:55 PM
lemons12's Avatar
i like the sound of 2.5 inch better over 3 inch for one, many more will agree..
as far as clearance, you should be ok depending on who you have do it..
do a xpipe, that gives the most hp.. its only 2-3 hp over an h, but it is a good 10 or so hp over straight pipes out the back.. and yes i have seen this on back to back dynos, no i dont have sheets..
as far as what size flows the best, 2.5 inch should support you just fine..
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
Old 02-05-2009, 05:08 PM
SHDY 5.7's Avatar
Hmmmm. Well I have to look into getting an x-pipe. So x-pipe into 2.5in bullets eh? Should be easy enough.
Old 02-05-2009, 05:19 PM
AChotrod's Avatar
I have 3" X-pipe with bullets dumped before the axle, Its very loud, but my car is not a DD. heres a cold start vid.
http://www.youtube.com/watch?v=njvCezTUnlU
Old 02-05-2009, 05:22 PM
lemons12's Avatar
i would def. get an xpipe..
2.5 will be easier to bend up and IMO sounds better... should support plenty enough of hp for you..
if it were me, i would run them to some knockoff 1 chamber flowmasters.. flow almost as good as bullets but sound 100X's better IMO..
Old 02-05-2009, 05:34 PM
Black94Z28's Avatar
I am going to get duals come spring also. Couple of guys offered to install them around here.
Old 02-05-2009, 05:35 PM
lemons12's Avatar
what did they quote you for what kind of setup?
Old 02-05-2009, 05:44 PM
Black94Z28's Avatar
Contact Larry at Speed Inc, he shot me a quote and he did AC's car not too long ago. Looked like a really nice job
Quick Reply: True duals: pros and cons ?
