Lt1 Carbed 'Style" intake question.
Old 02-06-2009, 08:46 PM
MrPotatoeHead's Avatar
Default Lt1 Carbed 'Style" intake question.
Does anyone make this type intake manifold for a Lt1?
http://performance.vfnfiberglass.com...&productId=261
Because I was looking at the GMPP carb intake and its shaped for a carb only. And it has a divider in it too.
Old 02-06-2009, 08:55 PM
roadtrip120's Avatar
A lot of us run the sbc carb style intakes and have them converted over to lt1. Some delete the thermostat and some do not.
here is mine
Old 02-06-2009, 09:19 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
what is that thing behind your balancer.....lmmfao!!!
Old 02-06-2009, 11:22 PM
i dont want to hear it, its not there anymore.. Some thing else is
Old 02-06-2009, 11:55 PM
B'klyn9C1's Avatar
The carb intake that GMPP offers for the LT1/LT4 is a dual plane. It is what most people use for a street application. The divider is because one side only "sees" half of the carb feeding half of the cylinders for better vacuum signal to atomize the fuel and keep it in suspension from 0 to 6000 RPMs.
What Roadtrip120 and others use are single plane intakes which in carb applications are only used for all out race applications from let's say 4000 to 8000 RPMs. But since port EFI doesn't need a good vacuum signal to atomize the fuel they can benefit from the single plane intake's better breathing ability and straighter shot into the cylinder. BTW most OEM EFI intakes including the LT1/LT4 are technically single plane anyway.
Old 02-07-2009, 05:10 PM
So your saying machine the divider out and machine the hole a lil more? And with the SBC conversion is only new holes right?
Quick Reply: Lt1 Carbed 'Style" intake question.
