Best way to flush and clean out engine gunk/carbon buildup? - LS1TECH
Thread Tools Search this Thread
Old 02-08-2009, 10:04 AM   #1
Black94Z28's Avatar
Default Best way to flush and clean out engine gunk/carbon buildup?
As most of you know, Im going to be putting the 847 cam and spraying a 150 shot of n20 on my 132,000 mile, never been apart engine till it goes. Just wondering since I got the car with 120,000 on it and dont know the previous history, whats the best way to clean out the engine and remove any gunk or buildup inside?
I've used Seafoam in the past, just wondering if there is something better or use this in addition to something else?
When its done, i plan on giving it a good tune up with new plugs and wires (i think the MSD ones are starting to crack) and then filling it with Royal Purple synthetic oil.
Any thoughts?
Black94Z28 is offline   Reply With Quote
Old 02-08-2009, 10:17 AM   #2
I use Seafoam, and when I pulled my engine apart after I spun a rod bearing, it was really clean, especially for a 225,000 mile engine that wasn't driven nicely most of it's life. I also only used Mobil 1 full syn oil.
SprayedLT1 is offline   Reply With Quote
Old 02-08-2009, 10:28 AM   #3
Formula Freak's Avatar
One thing to keep in mind is if the motor has only seen conventional oil its whole life, there is a good chance synthetic will loosen or clean up sludge formed around seals and gaskets and then seep through most of them.Happened when I had 75,000 miles on mine with mobile 1 synthetic oil.I was ignorant at the time about synthetics and older motors but I have since went back to dino.
Formula Freak is offline   Reply With Quote
Old 02-08-2009, 10:57 AM   #4
Product called AutoRX, you have never heard of it because it ACTUALLY works and the company spends money on R&D instead of advertising.
Looks like you would be more interested in a big name than a useful product though.
96capricemgr is offline   Reply With Quote
Old 02-08-2009, 12:31 PM   #5
multmigs's Avatar
I've seen good results running new oil with 1 quart of ATF in place of 1 of the oil and draining that after a couple weeks of normal running or 500 miles whatever comes first, gotta remember that ATF is basically a 10 weight oil with alot of cleaners/conditioners....
multmigs is offline   Reply With Quote
Old 02-08-2009, 12:50 PM   #6
These days ATF has LESS detergent in it than motor oil.
ATF can do some cleaning just by being thin, but then you might as well just get some 0w-20 or 5w-20, easy to find because Furd and HonDA spec it.
Diesel oils actually have high detergent levels.
Old 02-08-2009, 01:08 PM   #7
SoxXpupPeT's Avatar
Quote:
yeah thats why people use diesel oils to break in there new short blocks. marvel mystery oil im sure will help clean up your engine good. i ususally run alittle bit mixed in with my mobil 1 10w-30. after my cam swap tho i might switch to a 40 weight oil.
SoxXpupPeT is offline   Reply With Quote
Old 02-08-2009, 06:01 PM   #8
leadfoot4's Avatar
There's a "clean-out" product/system called "Run Rite". It's similar in concept to Seafoam.
leadfoot4 is offline   Reply With Quote
Old 02-08-2009, 06:04 PM   #9
gregrob's Avatar
Auto RX is what I would recommend. Great product
gregrob is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
How To Seafoam Your Car ChocoTaco369 General Maintenance & Repairs 1153 07-21-2016 02:16 AM
Tore down 5.3 for turbo, LOOK OK?? Chiropaul Forced Induction 15 04-26-2014 02:11 PM
Intake manifold Asphalt Assault General Maintenance & Repairs 2 06-28-2011 12:24 AM
Removing Gunk From Engine Bay RENE'S RAGE Drag Racing Tech 14 03-23-2011 09:56 AM
headlight cleaning Texass683 Appearance & Detailing 5 03-18-2009 04:23 PM
Tags
build, car, carbon, clean, cleans, easy, engiene, engine, gunk, loosens, performance, product, remove, seafoam, sludge, synthetic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
