How do you take apart rear LT1 calipers
Old 02-11-2009, 07:41 PM
Motorboater
SilverGhost's Avatar
Default How do you take apart rear LT1 calipers
Nobody had send me any rears for an LT1 until this week now I have two sets sitting here to do. I got the piston and what not out that was easy, but how the hell do you remove the huge ebrake assembling thing? I'd really prefer to remove that rather than coat it all together at once, that would be a pain. That nut on the backside that appears to hold it all on just spins some kind of grease fitting on the other side when I turn it, doesn't do anything.
Old 02-11-2009, 07:45 PM
Formula350's Avatar
Assuming you don't get a good response by tomorrow around 11am CST, send me a PM and I'll look up an assploded diagram on AllData and fire you pictures And the steps it says to take it apart.
Old 02-11-2009, 09:11 PM
Motorboater
thanks!! that would be awesome.
Old 02-11-2009, 11:11 PM
shbox's Avatar
If you just want an exploded diagram, here is one.
Old 02-12-2009, 08:32 AM
Motorboater
Thanks. anyway to get a closer view on it?
Old 02-12-2009, 08:55 AM
FlamingChicken's Avatar
its been awhile since i took it apart but i dont think the grease fitting has to come out when taking the ebrake stuff off. i know theres a allen head bolt and a spring that has to come out and i think thats it. like i said though havent done one in a minute so no guarantees
Old 02-12-2009, 09:04 AM
Motorboater
i found a good exploded diagram on autozone's website of all places
http://www.autozone.com/addVehicleId...00c152800b8a2c
part number 3 is my problem. it has the nut, #12 on the back side, then a crush collar thing on the other side, #2. When you turn the nut #12 it just spins the whole thing #3. that's all that appears to be holding the whole ebrake thing on(#8)
thanks flamingchicken. yes If i got the spring out of the way I could get at the allen head which holds the 2nd guide pin, which also needs to come out. But it would still leave the entire ebrake bracket attached to the caliper.
Old 02-12-2009, 10:26 AM
NebWS6's Avatar
bwahahahaha.....told you!!!
It looks simple but it isn't... there was just another thread I ran across where someone wanted to remove it for weight savings and some others said they have removed it.... I'll look for it
Getting at that allen head confused me also...
EDIT.... not much info, maybe you could ask some of these guys though.
https://ls1tech.com/forums/lt1-lt4-m...e-removal.html
Old 02-12-2009, 12:48 PM
Formula350's Avatar
heh ya, it's the front page, not hard to miss.
I'm heading to the shop and I'll post with what diagrams they have (most likely the exact same as SHbox's)
Old 02-12-2009, 06:22 PM
Formula350's Avatar
SUM BITCH I totally forgot to email myself this page before I left >_<
Gah, I'm sorry man
Old 02-12-2009, 09:40 PM
Motorboater
Its ok, both guys said just leave the damn thing on and coat everything so that's what I'm going to do.
I did my first set of LT1 fronts this week also and they too were a pain compared to LS1 fronts lol.
Old 02-13-2009, 01:46 PM
Formula350's Avatar
Well, since I already got all the pictures made up, here they are for anyone else interested. Picture names reflect year (95-97). If they're different or not, I don't know, but the diagrams had more/less info depending on year, so I figured I might as well mentioned the years it showed the pics for just in case.
EDIT: Forgot a pic of the torque specs.
Attached Thumbnails How do you take apart rear LT1 calipers-95caliper.png   How do you take apart rear LT1 calipers-96caliper.png   How do you take apart rear LT1 calipers-96ebrake.png   How do you take apart rear LT1 calipers-97adjustment.png   How do you take apart rear LT1 calipers-97ebrake.png
How do you take apart rear LT1 calipers-97ebrake_attachment.png   How do you take apart rear LT1 calipers-torque.png
Quick Reply: How do you take apart rear LT1 calipers
