LT1 overheating
LT1 overheating
my LT1 is overheating again....only when i beat the **** outa it though....i can leave it running for 6 1/2 hrs w/o turning it off(sometimes i have to for my job) and it wont overheat. Only when i go out having fun with it does it do it(beat the **** outa it). i changed the waterpump(due to splines on the coupling being worn), thermostat, replaced all hoses and checked the radiator out and its not plugged....i am bout ready to give up on the car due to all the problems i've been having with it....
yea i know its a wierd problem i might just sell the car as my intro into f-bodies has not been good(fun to drive but can't handle any abuse or atleast mine cant)
look and see if the black part is there. underneath the car. it rubs when pulling up on curbs and ****. if that thing is gone theres no way it can get enough air.
is there anything restricting the rad?
nope even have papers for it, it was bought about a year ago, and i've tested it twice..(ive tested things twice cause i cant belive its still overheating after all that i;ve done)
well i mean i travled 104miles on the turnpike each day for work at about 80mph and nothin.....just when i accelerate hard or just got have fun in the parking lot.....
something is wrong with the car, cause even in phoenix, after beating on my car the heat rises a little but never over 205. maybe try getting an aftermarket tune to have the fans turn on sooner, and what temp thermostat are you running and what area of the country do you live in?
i live in miami florida and i have the stock 180 therm in it(i had a 160 in it but it still overheated) what i am wondering if its possible that the splines on the waterpump shaft(the shaft in the block) could be worn just enough that when i rev the motor high it doesnt move the waterpump as needed. i mean i dunno just a thought....at this point im all outa ideas...
I went through the same situation and a new waterpump took care of it for me. I took apart the old one and the new one to see if there was a difference in the blades and the old one was corroded bad. I could def see why it wouldn't pump like a new one. Hope that helps.
