Phil Veldheer Racings' Stock cube Naturally-aspirated 10 Second Formula
http://www.bmrfabrication.com/Featur...ilVeldheer.htm
what else is done to this car to get it to run 10.60 and it says unopened heads/intake meaning no port/polish work ???
i just want to see some "No NOS/superchargers/tubros ect. lt1 motors running 10's/9's"
Competitive stock Eliminator cars have as much or more money sunk into "unported" heads than we spend porting them.
They are limited to stock lift cams, BUT they throw the lifter off the nose called lofting.
They run aftermarket management and spin beyond the pcm's ability.
and like fatboy said they are racecars.
GIZMO a frequent contributor here runs in that class or at least has run in that class, he will tell you his way of going fast is more expensive than the way the rest of us do it. It is a challenge though and I think that is what those guys thrive on.
