Driveshaft Lengths
Old 02-22-2009, 12:11 PM
96Formula6spd's Avatar
Default Driveshaft Lengths
Hey I was wondering if a ls1 automatic driveshaft is the same length as a LS1 t-56 driveshaft. There is a guy selling a a automatic ls1 driveshaft for 60 bucks obo Locally. Let me know
Old 02-22-2009, 12:39 PM
96lt1m6's Avatar
they use the same shaft
60.00 for an aluminum shaft is a sweet deal
Old 02-22-2009, 12:43 PM
That is good to know I think I am going to call this guy up
Old 02-22-2009, 12:56 PM
fergymoto's Avatar
You better get that, That's about half of what they normally sell for.
Old 02-22-2009, 01:16 PM
emailed they guy and probably will get it today or tomorrow if he still has it
Old 02-22-2009, 03:24 PM
95z28camaro's Avatar
What about ls1 auto to lt1 auto, same length? Also heard they are alot weaker. Anybody know about what point the start to break(60ft and hp wise)? Been thinkin about doing this myself but dont want it breakin during a round.
Old 02-22-2009, 03:44 PM
fergymoto's Avatar
82-02 F bodies all use the same length driveshaft no matter transmission type.
Old 02-22-2009, 04:39 PM
Elliott's94Z's Avatar
Looks like you got your answer. You may also want to be sure it's balanced before putting it on.
Old 02-22-2009, 05:14 PM
Formula350's Avatar
+1
Also, 82-02 seats can all interchange Want some slick leather 6way electrics in your KITT, NO PROB! lol
Old 02-22-2009, 05:35 PM
mean_greenz28's Avatar
does this include V6 cars also?
Old 02-22-2009, 05:37 PM
Formula350's Avatar
Unless its a 2-piece (which I think some 3rd gens had).
RamAir95TA's Avatar
Yes it does.
Keep in mind that V6 cars not equipped with the Y87 package used a heavy 2-piece driveshaft that used a center support bearing. They can, however, be removed entirely and replaced with a one-piece unit from any year car.
Old 02-22-2009, 05:45 PM
ok yeah....my beater v6 has a 2 piece shaft and i don't like the way it looks and i think the center support bearing is going out....so any one piece driveshaft should be the same length?
Old 02-22-2009, 05:46 PM
Formula350's Avatar
Tis what the man said
Old 02-22-2009, 05:47 PM
96lt1m6's Avatar
no 3rd gens came with a 2 pc shaft
still cant understand why they put a 2 pc in the 4th gen at all,hmmmm.
as far as how strong the alum shaft is well there are a bunch of 10 sec.Ls cars with them with a stick that could be a different outcome especially mixed with traction it may
Old 02-22-2009, 05:49 PM
Formula350's Avatar
I knew I saw it before, just couldn't remember if it was under a 3rd or 4th. Thanks And I can't understand that logic either other than to preserve ground clearance for a certain engine and tranny combo :\
Old 02-22-2009, 08:23 PM
well i got a deal going to go get me the a aluminum drive shaft for $60 tommrow
Old 02-22-2009, 11:58 PM
Formula350's Avatar
Lucky you Seems almost too good to be true so make sure there's no dings or gashes in it. Look it over closely!
Old 02-23-2009, 12:23 AM
Going to, if it looks bad at all ill pass and keep my stock steal one which i think is unbalanced.
Old 02-23-2009, 07:47 AM
James Montigny's Avatar
83-02 shafts are interchangeable.
Auto/Manual/V6/V8 ... doesn't matter.
(Trans/rear end combos from 82s are not compatible with later 3rd gens)
Some early 4th gen V6s (3.4L) came with a 2pc shaft that had a bracket mounted to the torque arm.
It can be removed and replaced with a 1pc shaft. (Very popular mod for 3.4 owners; I've done it many, many times for people)
And yes, $60 is a great deal. $125 is typical for a used shaft in good condition.
They're good shafts for 11+ sec cars, but I've seen guys shred them with bigger setups.
If you're planning on running low 11s or better, get a purpose-built aluminum of Chromemoly shaft.
Quick Reply: Driveshaft Lengths
