errrr what do i need???
Old 02-23-2009, 09:01 AM
dante1313's Avatar
Default errrr what do i need???
for my car to run 12.5's??? that's all i really want right now
Old 02-23-2009, 09:08 AM
TABBED 5.3's Avatar
with the firebird in the sig? it should do it now on the 100 shot. otherwise a stall if its an auto. gears, drag radials, cut out, might need a cam too. good luck
Old 02-23-2009, 09:09 AM
7.0 camaro's Avatar
more nitrous. what do you run now?
Old 02-23-2009, 09:24 AM
96lt1m6's Avatar
you should be in the 12s with whats in your sig...
97 Ws6 TA conv heavy pig
slp shorties,catless Y-pipe,cut-out,125dry(yuk),nitto DRs no other mods
12.4 @ 106 sprayin out the hole 1.6 60' in 2800' DA
you having a lighter car,Lts and most likely better DA you are there!
Old 02-23-2009, 10:09 AM
Formula350's Avatar
You have an A4 or M6 trans? If the latter, I'd say practice launching, if an A4 I'd say get at least a 2500 stall.
96lt1m6 is right hough, you should be close to that if you can pull off a solid launch. Otherwise I'd say some suspension mods and you're set! There's been stock LT1s with just full suspension that hit mid-high 12s, so a 100shot should solidify that.
Old 02-23-2009, 10:14 AM
z_speedfreak's Avatar
yeah should should be seeing those times already. whats your DA? and whats your 60'?
ditch the chokemaster and do some weight reduction maybe
Old 02-23-2009, 05:36 PM
lt1-xjs's Avatar
Atleast a Yank SS 3600, anything less is a waste of time.
Old 02-23-2009, 06:52 PM
Formula350's Avatar
Everytime someone recommends a purely racing part, I have to remind them that not everyone is out to make their car a dragster :\ Some of these are DDs that they like to take to the track and a 3600 is going to kill the gas mileage. That's why I mentioned at least a 2500 but I wouldn't go over 3K if is driven on the road a lot.
Old 02-23-2009, 07:09 PM
RamAir95TA's Avatar
Sounds to me like the OP isn't concerned with anything else, because all he wants is to run faster times. I've used a 3600 converter as my daily driver for 6 years and, while gas mileage suffers a negligible percent, the gains at the track are worth 1 or 2 mpg, IMO, especially when the priority to go faster supersedes gas mileage on a V8 12-second car. And if gas mileage really is a concern, make sure you get a lock-up converter.
Go with a 3500+ stall. With the bolt-ons mentioned and a sticky tire (and a rear that can handle it) on top of a 3500 stall, you'll catapult yourself into the 12s easily (all motor - no nitrous).
Old 02-23-2009, 07:13 PM
94Z28rag's Avatar
What are you running now? What kind of 60' times?
Before anyone can answer you well, you have to answer those two questions.
Old 02-23-2009, 07:20 PM
94Z28rag's Avatar
I completely disagree. It has nothing to do with there being a definite threshold for what can or cannot be driven on the street. Driveability comes down to personal preference. As for gas mileage...If you drive a V8 FBody and that is a concern of yours, then
Old 02-23-2009, 07:52 PM
Formula350's Avatar
I never said it was impossible to drive on the street Or if I did, please quote that part. I said it'll hurt the fuel economy. Our cars get quite good fuel economy, so why can't I enjoy the best of both worlds? Doesn't seem like I'm asking too much. And you can go faster with out touching your motor or transmission, I already pointed that out.
Old 02-23-2009, 08:17 PM
Razor_Blade's Avatar
He's probably hitting the 100 shot and spinning the Nittos. A set of Micky Thompsons would most likely get him some 12.5's.
