What sealant?
Old 02-23-2009, 02:18 PM
jrock692's Avatar
Default What sealant?
I am about to put my intake mani back on. What sealant should I use in the valley? I have copper high temp, will that be fine, and should I go over the gaskets as well?
Thanks guys
Old 02-23-2009, 02:31 PM
RamAir95TA's Avatar
I prefer Permatex black silicone.
You only need to use silicone on the block surfaces in the front and rear - install the manifold gaskets dry. Install the gaskets then run a 1/4" bead of RTV about 1" overlapping onto the intake manifold gaskets from the block surface.
Old 02-23-2009, 02:39 PM
jrock692's Avatar
Thanks for the info.
Old 02-23-2009, 05:32 PM
multmigs's Avatar
X2 I just did this and it worked great, you will probably be fine with the High temp copper stuff you have just look on the tube to make sure its oil/gas resistant make sure you TQ the bolts down in the manner described in the service manual
Old 02-24-2009, 09:12 AM
01Z28M6's Avatar
What I liked about the Permatex black (500°) was the texture and the way it applied out of the tube. It allowed me to easily put down a near perfect bead. The manifold sealed completely with it.
If you haven't already finished, use a couple of pencils in two or more bolt holes - catty corner fashion, to guide the manifold straight down.
Old 02-24-2009, 09:43 AM
RamAir95TA's Avatar
Be careful using pencils. I used them the first time I did my intake manifold fix and they EASILY broke off inside the bolt hole!
Old 02-24-2009, 09:53 AM
shbox's Avatar
I have used the Permatex copper. It works well and resists heat better than the black.
