383 Block Clearancing
Old 02-23-2009, 06:29 PM
myltwon's Avatar
Default 383 Block Clearancing
I assembled my shortblock using the standard eagle 383 kit with ARP rod bolts and the RA doesn't hit anywhere in the block, rod bolts come close to the block but never make contact.
is there is a certain "breathing room" required even if the RA doesn't make contact with the block?
thanks
Old 02-23-2009, 06:35 PM
fergymoto's Avatar
Most prefer .040-.060 clearance
Old 02-23-2009, 06:37 PM
myltwon's Avatar
alright thanks I was looking for an exact number
Old 02-23-2009, 06:57 PM
BALLSS's Avatar
you also want to confirm pan clearance. I did it without gasket just to give me even more room with the pan gasket. #2 rod bolt, IIRC, made "slight" contact. Just massaged the bottom of pan with rubber mallet from inside slightly and checked again.
better to have someone rotate engine with your ear to the pan.
Old 02-23-2009, 07:45 PM
lifeisgood's Avatar
i bought a new pan to clear mine, and notched the block
Quick Reply: 383 Block Clearancing
