O2 sensors not reading...
Old 03-01-2009, 12:27 PM
Green3spd's Avatar
Default O2 sensors not reading...
A friend and I replaced my Oil Pan and Timing cover gasket due to a serious oil leak and in order to remove the oil pan we had to unbolt headers and unbolt motor mount and raise motor..
Well everything went back together smoothly but none of the four O2 sensors are reading... Car runs ok, just like its running in closed loop ALL THE TIME..
Threw a P0154 code(O2 sensor Circuit No Activity Detected Bank 2 Sensor 1)
Also threw a P0100(Mass or Volume Air Flow Circuit Malfuncton)
Is there a Fuse I should check?
-Kris
Old 03-01-2009, 12:28 PM
shutzero's Avatar
you might have ripped one of the wires coming from the harness somewhere?
Old 03-01-2009, 12:34 PM
Green3spd's Avatar
Where should I go?
Old 03-01-2009, 12:59 PM
shutzero's Avatar
just follow the wires that come off of the o2 sensor as far up as you can and see if any of them got cut in anyway
Old 03-01-2009, 01:41 PM
shbox's Avatar
If the O2s are not fuctioning, it will be in OPEN loop all the time. Check fuses first.
Old 03-01-2009, 01:46 PM
impaled's Avatar
as odd as it is i had the P0154 before and seafoamed the car and the code went away. i think that might have been a coincidence though.
also with the headers, check your extensions, maybe a wire popped off of the connector between the factory harness and the extension.
Old 03-01-2009, 02:33 PM
97pontta's Avatar
I'd check fuses first, they are on the front drivers side corner of the engine bay.
I a problem with my O2's a while back and found blown fuses. Turned out one of the bundles of wire from the PCM running down the passengers side wheel well had a broken loom and laid against my LT headers and shorted an O2 wire, it was in a spot that was not easily seen.
Old 03-01-2009, 02:40 PM
Green3spd's Avatar
I checked fuse under hood.. it was good.. I have a scanner in my car and bank 1 sensor 2 was reading 444 millivolts constantly... I think I read somewhere if the O2 reads a constant volt, its bad??
Old 03-01-2009, 06:24 PM
97pontta's Avatar
The down stream(sensor 2) are for emissions, and depending if you have them disabled for an ORY they may have a constant reading. Mine are disabled due to the ORY and the reading never changes.
The up stream sensors (sensor 1) are what your worried about, their reading should be bouncing high to low few times per second. If the fuses are good start checking the wires, look for something that is unhooked, pinched, broken, ect. Its not a fun job.
Old 03-01-2009, 08:47 PM
Green3spd's Avatar
Im sorry.. Bank 2 sensor 1 failed... So it is the front sensor..
Old 03-01-2009, 10:05 PM
97pontta's Avatar
Is bank 1 sensor 1 working?
If so do a quick test and swap the O2 sensors with each other from bank to bank, if the problem follows the sensor you have a bad sensor. Another tip is to mark the sensors before you go swapping from side to side, you don't want to find you have a dead sensor and confuse the two.
If one of the sensors is bad it could have gotten hit, bumped, dirty or damaged when you were working on the car.
Old 03-01-2009, 10:25 PM
Green3spd's Avatar
Ok.. on my scanner its says: P0154/P0100
0.0 on BOTH front O2 sensors (and both rears, but they're tuned out)
Bank 2 sensor 1 is reading 444 millivolts constantly
Bank 1 sensor 1 is reading normaly...
I've been reading and it seems to throw the P0100 code after a header install..
Could my bank 2/1 be reading weird bc I burned a wire and would that cause my MAF to read funny???
Car was fine with NO CODES before the work we did...
BTW.. it says "NO ACTIVITY" not "MALFUNCTION"
Old 03-04-2009, 09:23 AM
ws6_z28's Avatar
When it reads that dummy value, 450 usually...it just means its not receiving any signal from that 02 sensor. If everything is hooked and no burnt wires...just replace it. You might have knock the sensor around or got oil on it...they aren't that much to replace ~50 to 60.
Old 03-04-2009, 09:31 AM
Green3spd's Avatar
Hopefully today Im headed back out to the lift and Im goin check the wires, It was fine before we started and as soon as I started it up the SES came on.. Surely we burned/cut a wire. Ill keep you updated..
Old 05-27-2014, 09:54 AM
bigz28man's Avatar
Hey guys i need to bring this post back up and hijack it....sorry. i had my check engine light come on yesterday. Scanned it, scanners states both passanger and driver side upstream o2 sensors no activity. Any ideas, I could understand one not active but both? I checked fuse box under the hood labeled engine (20 amp fuse) and the fuse is not broken.
Quick Reply: O2 sensors not reading...
