injector question
injector question
I am in the late parts of gettting my engine back together and I need to know if I need to upgrade injectors, this is my specs
355 stock compresion cc503 52mm tb lts ory !air and egr cai 1.6 rr
Thanks in advance
Andrew
Thanks in advance
Andrew
You can use your stock injectors at that power level, but don't plan to go much further (ported heads, bigger cam, etc.) without upgrading. Ideally you'll need to calculate your injector needs though.
I used the stockers with my XE236 for awhile and duty cycle was peaked around 93%.
Just do injectors now,if your going to tune it tune it once with the correct injector,that way you have room to grow.you will be at 90 plus percent duty cycle and the injector isnt very efficent at that duty cycle.Just went threw this with another member i just tuned,he put 30s in it and was at 75 to 80 % with the 30s.he made 339whp with a cam and long tunes.
