Would i benefit from a larger TB?
Old 03-02-2009, 01:02 AM
hitmanws6's Avatar
Default Would i benefit from a larger TB?
My new setup will involve headers, a cam, catback, ported intake and a few other things. So would i benefit from a larger TB?
Old 03-02-2009, 01:40 AM
DroppedM6Z's Avatar
I know ed was using a 58mm on this 383, when he went to a 355 he when back to a stock TB and Still ran some 10.30s in this TA.
http://video.search.yahoo.com/video/...d=000118182623
So unless you stepping up in cubes , i'd stay with a stocker and invest in something else
Old 03-02-2009, 01:45 AM
hitmanws6's Avatar
i might be going to a 355 but idk if thats enough to make it worthwhile. and my car will never see the track so 1/4 mile times dont do anything for me
Old 03-02-2009, 01:55 AM
DroppedM6Z's Avatar
Cool i Had a 355 in my 95Z. The time he runs is great and all, but im just really trying to say, its not needed for a 350 or 355
Old 03-02-2009, 02:23 AM
hitmanws6's Avatar
thats all i needed to know. thanks guys
Old 03-02-2009, 09:50 AM
ss.slp.ls1's Avatar
Overkill for your car. Maybe a 52-58 on heads/cam/n2o, but not a bolt-on 350.
Old 03-02-2009, 10:27 AM
Elliott's94Z's Avatar
It wouldn't be much. I would save the cash until you did some head work.
Old 03-02-2009, 02:29 PM
Stroked97TA's Avatar
I agree with ss.slp.ls1. It might sound a little bit better, but that's about it. Wait to put on a tb when you have heads/cam. If your car won't see the track and you're not that worried about it, then just stick with what you have until you start to crack the engine open and create a reason for more airflow.
Old 03-02-2009, 05:20 PM
wrd1972's Avatar
Someone check out my build (sig). I curently have the 52mm TB. No power adders. Do you think I would benefit from the 58mm TB?
Old 03-02-2009, 05:25 PM
ss.slp.ls1's Avatar
I'd say that your 52mm TB is capable of supporting the horsepower you are making. You might have a marginal gain by switching to a 58mm, but I would only do so if you could sell your 52mm TB to make up some of the cost of the 58mm TB. Then It might be worth the swap. I have a 52mm TB on my cam-only car, which is over kill, but I got a good deal, so I picked it up now, and I can use it when I go heads/cam/n2o.
Old 03-02-2009, 06:29 PM
You might pick up a pony or two. Not worth changing it out unless you have a buyer for your 52 like SS.SLP said. I'm surprised you didn't buy a 58mm when you had Lloyd port your intake and did the H/C swap.
Old 03-02-2009, 06:39 PM
wrd1972's Avatar
Thanks for the replies. I am going to get a new dyno tune Saturday and I thought about getting one and testing bots sizes. Sounds like it aint worth the expense at this time.
Old 03-02-2009, 06:42 PM
Yeah your air foil kinda makes up for it...kinda What electric cut out did you go with?
Old 03-02-2009, 06:44 PM
wrd1972's Avatar
It was a used QTP I think.
Old 03-02-2009, 06:54 PM
ss.slp.ls1's Avatar
In regards to just bolt-ons, I'd go with a EWP before anything else.
Old 03-02-2009, 07:04 PM
wrd1972's Avatar
I dont want an EWP. I will give up those ponies for piece of mind reliability if i want to drive it distance.
+1...that would be good for another 10-12 hp. The Meziere HD pump is a nice upgrade.
Quick Reply: Would i benefit from a larger TB?
