Bbody tranny swap question...
Old 03-03-2009, 01:03 PM
ss.slp.ls1's Avatar
Default Bbody tranny swap question...
Alright, I just swapped a LT1/4L60E out of a '96 Impala into my buddy's '94 (he calls it '94.5, so I guess it has changes that I don't know about) Buick Roadmaster. We are using the wire harness from the Roadmaster.
It appears that the two tranny's use different vehicle speed sensors. The Roadmaster had it on the drivers side of the tail shaft, the Impala has it on the passenger side. Can you simply swap the sensors? Do you have to swap tail shafts?
Old 03-03-2009, 04:23 PM
96capricemgr's Avatar
Going to need to open the tranny up. I am not going to even try and go into detail but I know the 95+ trannies are PWM the 94 car is not setup for that. So you need to go into the tranny and modify some things. Look to someone else for details though.
Tailshaft housing swap is easy, do that.
Old 03-03-2009, 04:27 PM
ss.slp.ls1's Avatar
So he can't even use that tranny with the '94 harness? We were going to use the '96 computer, will that solve the PWM problem, or does he need to use a '95+ harness?
Old 03-03-2009, 04:35 PM
Internal differences, pump and valvebody are different. I am fairly sure it can be used, but again you need to make some internal modifications.
Old 03-03-2009, 04:37 PM
ss.slp.ls1's Avatar
What can be done so that we don't have to modify the tranny? '95+ PCM? '95+ wire harness?
Quick Reply: Bbody tranny swap question...
