Did I just Coc% my allignment w/ engine install?
Sorry if this should be in another section please move it, but my ?? is that today I'm putting my engine/trans/K member back in the car from the bottom, I'm noticing that the driver side pin on the K member has a semi tight fighting hole to go into on the driver's side of the frame, the passenger side however seems to have a slotted hole with alot of room to move around, and as I'm jacking/tightening it all back up there seems to be alot of play with regard to where the K member sits on the frame. So my ?? is have I just destroyed whatever wheel allignment I had previous to this and do I need to go immediately to have it checked once I pull the car out?? I did the drop it from the bottom method partly b/c it would seem to not disturb any allignment bolt?
Migs
Migs
Migs
Migs
I have dropped out many engines, never once had an alignment issue.
