Tach hook up
Old 03-07-2009, 01:15 PM
93blacktransam's Avatar
Default Tach hook up
o im hooking up my tach on my 93 camaro....where does the green wire go to get the rpm readings it says the green wire on the coil but im not sure what wire and where at ...Input please...thanks
Old 03-07-2009, 01:25 PM
cgroh89's Avatar
I used the White wire after the tach filter. it is tapped up in your harness going to the coil.
Old 03-07-2009, 01:33 PM
by tach filter are you talking about the lil box looking thing or what
Old 03-07-2009, 01:34 PM
cgroh89's Avatar
Yep, That is what I went off of
Old 03-07-2009, 01:38 PM
ok and you mean after the filter as in going to the opti or on the side going to the firewall harness
Old 03-07-2009, 01:55 PM
Formula350's Avatar
Run it right off the coil, works best I feel on our non PCM cars (we're ECM remember). It's the white white, I'd tap in after the (what I assume is) a filter.
Though for anyone reading this with a 94+ it's PCM connector pin A13
Old 03-07-2009, 03:05 PM
can someone post a pic i looked at the wires it a bit confusing
Old 03-07-2009, 03:15 PM
cgroh89's Avatar
I just swapped out my harness but if no one does ill take a pic on the old harness when I get home ( be a few hours at work )
Old 03-07-2009, 04:03 PM
ok thanks for the help
Old 03-07-2009, 09:35 PM
Formula350's Avatar
There's 4 wires on the coil. I think it's 2 reds a black and a white. Either way, it's the white one
Old 03-07-2009, 10:05 PM
cgroh89's Avatar
Sorry its a bit late been working on putting my new system in
Old 03-07-2009, 11:07 PM
Formula350's Avatar
Might jsut be the bad pic, but that doesn't even look like the coil plugs.
Old 03-08-2009, 08:58 AM
cgroh89's Avatar
I never said I did thats where I had mine and it worked
Old 03-08-2009, 04:11 PM
Formula350's Avatar
Ah I see, my bad! I have no clue where that is at though lol
Quick Reply: Tach hook up
