Lt1 cc503 anyone have dyno #'s
Ok car is coming apart next weekend Maybe. Time to install my new motor here is a list of mods .030 (355) around 11.1 comp, cc503, 918 beehives, pacesetter longtubes, EWP, double roller chain, CAI, magnaflow catback, also going 6" rods. Does anyone have any dyno#'s on their car with similar mods? I'm just trying to get a idea of how much I can expect. Also #'s with this cam only on stock heads and stock bottom end would be nice. All the bolt ons so far made a noticeable diff I hope to hell after this build I get what I'm expecting my goals are mid 11's. Car runs 13.48 with a 1.9 60' yea bad traction,with long tubes, 2.73's, vig 3500, and magnaflow catback, and 52mm t-body. Oh BTW the 3.42's are going in the rear befor car hits track again also with some 26" mt's
I had to edit this the 13.48 was ran on stock short block stock heads stamped rockers BONESTOCK LT1
Ok car is coming apart next weekend Maybe. here is a list of mods .030 (355) around 11.1 comp, cc503, 918 beehives, pacesetter longtubes, EWP, double roller chain, CAI, magnaflow catback, also going 6" rods. Does anyone have any dyno#'s on their car with similar mods? I'm just trying to get a idea of how much I can expect. Also #'s with this cam only on stock heads and stock bottom end would be nice. All the bolt ons so far made a noticeable diff I hope to hell after this build I get what I'm expecting my goals are mid 11's. Car runs 13.48 with a 1.9 60' yea bad traction,with long tubes, 2.73's, vig 3500, and magnaflow catback, and 52mm t-body. Oh BTW the 3.42's are going in the rear befor car hits track again also with some 26" mt's
It won't be cam only right now my engine is bone stock internally those mods listed is the new engine. I think with my current mods and with the gears and tires I can hit 12' high 12's I'm on street tires and don't come off the line hard because of serious traction issues but I do trap at 105. But I think your right 2 seconds is alot may have to finally get the nerve to spray it. Have a coldfusion kit in the car but yet to hit it to scared for the highmilage bottom end.
mine did 330/345 while getting very hairy above 5000rpm. this dyno was done with a tune for a mega lift custom cam, so you can essentially say it was not tuned correctly. the block is zero decked and I have a valve job as well. in my experience, all I can say is that you can have the best parts in the world but if your A/F is way the phuq off, it wont matter. get a good tune, and I am sure you will see 350rwhp+
Ill be doing the same swap to my lt1 i have in the garage ready to go in my car for next season. But im definetyl going to get a set of heads for sure as its a biatch to re&re these motors. If your saying we can get 350rwhp cam only i should be able to net another 10-20rwhp with a decent set of heads
