True Duals. Has THIS idea been proposed?
Old 03-10-2009, 04:01 PM
wrd1972's Avatar
Default True Duals. Has THIS idea been proposed?
Okay, I am getting educated on true duals pros and cons. What I have learned is there are terrific gains in power but the downside is less ground clearance and they might be noisy as Hell due to limited room for full size mufflers for a daily driver, or in my case a fun car that barely ever sees the track.
I have an idea that would give me better flow, great ground clearance and might not be race car loud. One would not have to use bullet mufflers or resonators but yet use a full size muffler.
If one were to copy the 2.5" pipe routing like what bassani uses:
http://stealthram.com/bassanidualexhaust.htm
And use this Dynomax full size muffler in the stock location:
http://www.jegs.com/p/Dynomax/760549/10002/-1
Would this make a true dual setup that would accomplish all three of my goals?
Old 03-10-2009, 04:22 PM
Turnin20s's Avatar
I did basically that only with a 2OTL copy I'll go dig up some pics
ss.slp.ls1's Avatar
I guess so, don't know how it will sound though. I know of a guy who welded two bullet mufflers in series on each pipe of his true duals. It helped a lot to quiet it down.
Old 03-10-2009, 04:34 PM
Turnin20s's Avatar
Now in the first few of the pics the I pipes are hanging down really low, but thats because the Clamps I used would not hold the pipes together, but I changed them out and its good now and they sit up about 2.5" higher
I used a magnaflow dual in/dual out muffler though. Its pretty quiet on idle and while cruising, but at WOT its pretty loud.
Old 03-10-2009, 04:41 PM
Turnin20s's Avatar
IMHO it sounds really good and I have got nothing but compliments on it and how alot of people like it because its not SO loud. I had bullets dumped before, but that was way too loud for my taste. Plus I love the look of the 2OTL and had never seen it done in true duals
Old 03-10-2009, 05:06 PM
camar0corey's Avatar
Turnin20s, is that a tunnel mount torque arm? I want duals out the back due to scrapping as I DD my car, but I've got SLP subframe connectors and a Spohn t/a.
Old 03-10-2009, 05:39 PM
wrd1972's Avatar
Did you buy pre bent pipes or did you have a shop bend them? Any comment on power gains over the single pipe?
Old 03-10-2009, 05:46 PM
xx_ED_xx's Avatar
Does bassani sell that setup or is that something some one made?
Old 03-10-2009, 06:36 PM
wrd1972's Avatar
Bassani did at one time, not sure if they still do. It was $1000.00. Yikes
Old 03-10-2009, 06:44 PM
Puck's Avatar
I have done that with the magnaflow 3" dual in dual out muffler. It does not have the crossover inside though - I used a magnaflow 3" x-pipe before it then dumped the muffler before the diff. It is just as loud as the bullets were but with more ground clearance. Each inlet and outlet is still a seperate straight through pipe.
The muffler alone is like 175 though...I have pics posted somewhere of the setup, but I am not at home right now to upload them again. It is about even with the lowest part of my adjustable torque arm, and still higher up then the elbow off the drivers side header collector(which was then the lowest point of my exhaust).
Old 03-10-2009, 09:14 PM
BlackLT1Z's Avatar
I like the Keystone light can.....
Old 03-10-2009, 09:21 PM
Formula350's Avatar
I say go spendy or go home! Use oval exhaust! But if you want some retarded "think outside the box" idea... Get some oval (or not) 4", get all the bends put in as if for single, and then cut it down the center the whole way. Weld in a flat separator piece where you've cut and then you'll have duals in a single 4" pipe
.... Or BFH a new exhaust route down the drivers side
I like the fact that they're (I think) 24oz cans, and 5 are gone
Old 03-10-2009, 11:11 PM
xx_ED_xx's Avatar
Yeah I want to true duals on my car. 454 with dual 3 inch's should sound nice. But I want it out the back where the cut outs in the bumper are.
Old 03-10-2009, 11:57 PM
SS MPSTR's Avatar
I have the Bassani system, and I don't think its too loud at all.
Old 03-11-2009, 12:00 AM
xx_ED_xx's Avatar
I have heard that gmmg sells a true system and so does texas speed. Is this a pipe dream or reality?
Old 03-11-2009, 12:11 AM
Turnin20s's Avatar
HAHA 16oz cans and they do help for those tough bends that are hard to figure out, just sit down, grab a beer, and it will come
But to answer some questions I bought a couple boxes of prebent pipe sections and a summit x pipe, and a magnaflow muffler off of ebay that has the internal pipe so my car has 2 of them LOL. The exhaust was fabbed up in my garage by me and I have probably 35+ hours into it and its still not 100%. I still need to add some bracing to the brackets in the rear that go to the stock hangers and add a front hanger for the I pipes. Bassani does sell a kit similar, but I do not have $1k to waste on some bends, and with the muffler, clamps, x-pipe, and regular old straight pipe I have probably ~$400
When I had a tunnel mounted TA I had true duals with bullets dumped at the axle with an x-pipe and that was a real pain in the *** to work around. I swapped the tunnel mount for a full length arm when I swapped to the 6 speed and the new exhaust setup. Tunnel mounts are WAY too noisey with a 6 speed, always clunking, now my UMI piece is quiet.
Can't comment on power gains from a single setup to true duals, but from dumped bullets to the 2OTL setup there is no difference in power, but the sound is SOOOOO much nicer. I can actually have a conversation with the passenger without yelling at them with the windows up or down LOL, but the WOT throttle note is awesome. Hopefully when it gets nice out I'll make some clips of it to give you a better idea of how it sounds. Before I did the 2OTL setup I was looking at buying a 4" mufflex system and I'm really glad I decided to go the route I did because the 2OTL look is just simply badass IMHO
Sorry for all the pics in the previous post and rambling on in this one, but I hope I helped someone out
BTW thanks for the comments guys
Old 03-11-2009, 12:15 AM
Formula350's Avatar
Hoh! I see wut u did thar!
Old 03-11-2009, 12:20 AM
xx_ED_xx's Avatar
LOL no pun intended
Old 03-22-2009, 07:21 AM
wrd1972's Avatar
So if I go 2.5" dual exhaust into a dynomax X flow muffler and ditch the 3" single exhaust. Do you guys think their will be significant gains or would it be a waste of time and money considering my power levels? I have an exhaust fabricator currently looking into the cost of the job.
Old 03-22-2009, 10:35 AM
myltwon's Avatar
2 1/2 dual flows over 3 single
so yes some gains should be made not sure how significant though
