TH350.. what flexplate?
Old 03-19-2009, 02:36 PM
1badzee's Avatar
Default TH350.. what flexplate?
What flexplate should I use when converting to TH350? I searched but the search function has been an epic fail lately.
Old 03-19-2009, 03:06 PM
kyle88transam's Avatar
as long as the converter is a dual pattern or small bolt pattern the stock flexplate should work. If the converter is made for a 168 tooth or large bolt pattern you will need a new flexplate and starter.
Old 03-19-2009, 07:10 PM
joelster's Avatar
I run the stock one.
