Granatelli VS Stock MAF Tune Results
Well we decided to make a run with the granatelli on my buddies 94 firehawk and log it. Then switch to the stock one, and run again to see the results.
With the granatelli the car was runnin rich, would black smoke when you started it cold lol.
Granatelli MAF was 890-910mv on the 02's. Stock descreened MAF it's down to 820-830 under WOT.
Granatelli was 36deg spark advance with 10 deg of knock retard, for 26deg of total advance
Stock descreened maf yielded 35deg of spark advance and only 4deg of knock retard under wot, for 31deg of total advance.
AFGS numbers were much higher with the Granatelli. 210+ vs 160-170 on the stock one.
Car seems to run better to me. It definitely sounds different. It likes to rev a lot more freely, and seems to get through the gears quickly.
With the granatelli it had more midrange 'snap', but seemed like it was struggling to rev. I credit this to the stock maf leaning the car out quite a bit. It actually may not 'feel' as gutsy, but would probably be faster on the track because it gave it more top end.
We had to make 2 runs because evidently unplugging the maf throws the car into open loop mode and the first run we made with the stocker was in open loop lol. The files below are in closed loop for both the Granatelli run and the Stock desc MAF run.
The stock descreened maf is staying on the car and the Granatelli is for sale if anyone wants it.
Here are the TTS Datamaster files if anyone would like them.
Granatelli MAF
http://forddieselpower.com/grfiles/granatellimaf.uni
Stock Descreened MAF
http://forddieselpower.com/grfiles/s...closedloop.uni
Discuss.
Granatelli MAF
Discuss.
LS1TECH Sponsor
I agree and my Gran Maf found it's way as a target on a firing range.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
I had a can tuned to a granitelli swapped to the stocker while still on the dyno, same tune same everything factory lost 15RWHP. May have been where it was tuned for the Gran. but thats what happened.
Stock MAF only flows 670cfm.
http://dtcc.cz28.com/flow/index.htm
I am buying a Z06 MAF and just using TC to interpolate my MAF tables. I don't see what's so hard about that. Anyone who sticks a aftermarket MAF in a car without changing the table can't expect the car to run well. Pro Tuners don't like aftermarket MAFs because they like to "cut and paste" from car to car. If you have an aftermarket MAF then you make them "work" because they have to change the tables then drive it a couple of times to get it right. Anyway, the gains I bet are 15+hp for a cam/heads car.
