For The Peep's With Lots Of Oil Leaks
Ok my car is leaking from the front and back seal, Oil pan gasket, and timing chain cover. Well i am going to replace all seals and gaskets but im going to wait until i get my H/C package ready. Well while i was at AZ this weekend i seen a new product called Bar's leaks, it is a quart size bottle looks like a quart of oil. It says it is mostly to seal the rear seal. I changed my oil and put it in.I drove the car for a few hours came home and parked it, normally after driving it hard for a while i would get a nice size puddle but when i checked there was not a drop of oil under the car. THIS STUFF REALLY WORKS!!!, now i hope it is not bad for the motor seeing that it is a whole quart. If anyone else has used this please chime in. Good or bad let me know
Some of Bar's stuff works pretty good, but like their radiator stop leak that is the pellets (that looks like plastic, and could very well be), you want to be cautious of. It can get lodged in the water pump impeller and then hinder cooling performance :\ Might stop the leak, but then you'll have to change your pump lol
Yours was a pure liquid right? No chunks or large sized bits? If it was a liquid you should be fine, though if it contains any sort of wax-like substance, there may be need for slight concern. Word around the campfire was that's why Penzoil wasn't so great, was because it had some wax in it, who knows how accurate that is though.
I'd think a good oil flush with Sea Foam would do the trick to rid the motor of it if you planned to do the gaskets later on. I'm sure you'll be fine
The additive may actually be keeping his crappy leaking gaskets together for now, and after a seafoam they may all fall apart and start leaking worst then before at once.
If it stopped the oil leak, run it for now until you can change the gaskets. Do not make it a common practice though - those additives are called "Engine Honey" for a reason and you don't want to end up with an engine that relies on them.
They are not ment to be permanant solutions, just temporary band-aids for the problem.
I got a few leaks and I would be better off replacing the seals than adding something like that to my oil. I think those products are meant to be more of a band aid(sp!?) rather than a permanent fix. I use to run the pellet crap in my cooling system when I cracked my cylinder heads...and it worked until I got on it a little then temps shot threw the roof !
