Rocker Arms
Rocker Arms
So my new rockers **** the bed for whatever reason. but there garbage
as you can see. im rebuilding my engine so nothing like that happens again. i had purchased off a member of this forum PRW full rocker arms which i must say are a very nice quality piece. unfortunately i didnt know they were SA and i have a NSA set up that id like to keep that way im going to be running LE's 223/230 cam at around .600 lift should i stick with these rockers or should i get something else thats non self aligning ?
ive been looking at these
http://store.summitracing.com/partde...6&autoview=sku
but if anyone else has any suggestions or advice id appreciate it alot
Not everyone knows what to use and what not to use when running SA or NSA rockers. Several people have made the mistake of running SA with guideplates or with "high" lift camshafts when they shouldn't have. It's a easy mistake to make if you don't do much research or know anyone that's up to par with doing the correct thing. In Sox defense he is doing just the opposite, he's looking for guidance as to what to do so he goes the correct way.
i know that imnot supposed to run SA rocker with guidepaltes. perhaps my post was a bit confusing. the rockers i had just purchased i DID NOT KNOW that they were SA. thus now my dilema. do i run these new rockers without the guideplates? or do i sell them and get these
http://store.summitracing.com/partde...w=1&N=700+150+
sorry if there was a mix up guys im all over the place these days
Sox, i'm sure i told you they were SA, & they were listed that way in my add, anyways, i'm sure you'll be fine shifting @ only 61-6200, if you have ANY doubt, call Lloyd Elliott, if your planning on a larger cam in the future, i would just sell those SA rockers, then get some NSA with guideplates. Before you go through summit/jegs, check out the place were those came from there in Iowa, he has some great prices.
