LT1 Caprice Swap?
LT1 Caprice Swap?
So Ive been looking at this lt1 out of 96 Caprice. And I've been thinking of doing a swap since its got way less millage then my lt1. What I want to know is what difference are there are between the lt1 in my 95 Firebird and this 96 lt1 from the Caprice. Will the 96 lt1 caprice bolt right up or does require some modding. Also the Firebird has the 4L60-E.
The the difference between the heads is that the iron heads will flow slightly more, but will heat soak a little more. Basically, performance is comparable on a stock motor. I don't know if you will run into problems trying to run the B-body accessories or not, but if you swap over all of the F-body accessories, you'll have no issues.
EDIT: Also one thing to note, the '96 engine will have a crankshaft position sensor in the lower passenger side of the timing cover, just leave it there and don't worry about hooking anything up to it. I also think that there is a knock sensor on both sides of the block, just hook up the one on the passenger side normally and ignore the one on the drivers side. Or you can install the drain plug from the F-body block.
