Cam Bearings
Old 03-31-2009, 10:45 PM
96Formula6spd's Avatar
Default Cam Bearings
Hey guys I am going to be changing my cam out. Anyways I want to put in new bearings. Which ones should I get. GM replacement or is there another brand? Also how do you get them out and put new ones in.
Old 03-31-2009, 10:49 PM
RamAir95TA's Avatar
Replacing cam bearings warrants removal of the engine. I suppose you COULD do it in the car, but not without several curse words and angry faces. You need a cam bearing install tool (looks like a giant slide hammer).
Why do you think you need to replace your cam bearings?
That aside, I recommend Clevite.
Old 03-31-2009, 10:52 PM
Well the engine is going to be out. The old ones have 155k and I just think it would be good idea to change them out.
Old 03-31-2009, 10:55 PM
SoxXpupPeT's Avatar
it would be a great idea to replace them. my 157k mile cam bearings look like this
they all do too. i bought clevites
Old 03-31-2009, 10:57 PM
RamAir95TA's Avatar
JMHO, if you're going that far, might as well rebuild and replace everything else.
If your bearings look to be in good shape (no gouging, pitting, etc.) I would not hesitate to reuse them. Lots of people do cam installs at 150k plus with good luck. You just need to make ABSOLUTELY SURE you do not scar or nick the bearings during install, as this is one of the root causes for spun bearings after cam installs.
It's up to you on whether or not you want to take the gamble. I'd go for it and reuse them. Easier to maintain a clean environment with the engine out of the car.
Old 03-31-2009, 11:07 PM
well we might get someone to take out the bearings and reinstall them along with the cam
Old 03-31-2009, 11:17 PM
7.0 camaro's Avatar
i agree. if the engine is out. do it all. hell i would even do the freeze plugs too. and reseal whatever oil galley plugs and stuff like that you have. better now than later
Quick Reply: Cam Bearings
