Any benefit from this bolt on
Old 04-01-2009, 06:36 PM
305 h.o.'s Avatar
Default Any benefit from this bolt on
Just want to know if this intake piece will add any power or would you be able to fell a difference.
http://www.ws6project.com/user_stor/...e.php?pID=2521
Old 04-01-2009, 06:39 PM
slick1851's Avatar
Intake elbow by it self? Meh worth a tiny bit of flow.....You not going to feel alot.
But there cheap and flow a better so if you can get it for cheap, might as well for the right price.
Old 04-01-2009, 06:46 PM
305 h.o.'s Avatar
If I can find it cheap. So far just 84.00 bucks
Old 04-01-2009, 06:58 PM
ss.slp.ls1's Avatar
You will feel absolutely no difference whatsoever, spend your money elsewhere.
Power > Bling.
Old 04-01-2009, 07:35 PM
StealthFormula's Avatar
On my '95 I had a rip in my stock elbow so I swapped it out for a 1LE. Felt no difference whatsoever. If you can find one for next to nothing then I would go for it otherwise it would be wiser to spend the money elsewhere.
Old 04-01-2009, 07:40 PM
AChotrod's Avatar
Not worth it but looks better. I would go with a composite one though.
Old 04-01-2009, 07:45 PM
ThoR294's Avatar
gets rid of that floppy ***** in front of your engine
Old 04-01-2009, 08:23 PM
creepingdeath94's Avatar
Unless you have that ***** off already to clear your ewp :-p
Old 04-01-2009, 08:27 PM
slick1851's Avatar
I wouldnt pay that much for the thing
Old 04-01-2009, 08:29 PM
wrd1972's Avatar
Power > Bling.
None, zero, zilch, nada, negative
Old 04-01-2009, 09:19 PM
CAMJAG's Avatar
An air foil would do you better for less
TPIS has them on their ebay store for $35 plus shipping
Old 04-01-2009, 09:26 PM
gregrob's Avatar
Trick flow elbow F.T.W.
Old 04-01-2009, 09:42 PM
Elliott's94Z's Avatar
IMO...Do it. Everything counts and it's inexpensive. I like having the feeling of knowing I've done every last thing to my car bolt on wise...I'm just **** like that though. Get rid of the donkey dick factory one!
Old 04-01-2009, 10:05 PM
That's MISTER MODERATOR
Paul Bell's Avatar
That metal elbow will get pretty hot if you're sitting in traffic. It'll pass the heat along to the airstream and presto! LESS power!
Old 04-01-2009, 10:12 PM
That's why you go with the black ceramic like I did
Old 04-02-2009, 01:19 AM
gregrob's Avatar
I agree with elliot. I like the idea of it even if I can't technically feel the difference. Every little bit helps.
Anything you can do to help increase airflow into the engine will make more power theoretically.
If you really want to make it easy for air to get in, do the ls1 lid mod with a fernco. very little restriction that way.
Old 04-02-2009, 01:47 AM
collier341's Avatar
i got one off ebay from a company called CRT performance.. it was like 50 bucks with an airfoil.. WAY easier to take on and off than the stock one and looks way sweeter
Old 04-02-2009, 01:49 AM
Trans Am Jam's Avatar
it's great to have. but for the money it's not the best bang for the buck. If you're any bit creative make a custom intake elbow yourself, like a 90degree bend of SS.
Old 04-02-2009, 10:19 AM
GoFastKid's Avatar
+2 Just like Elliott said, everything counts. It all adds up and for how ceap the mod runs dollar wise why wouldn't you? Plus you eliminate that huge air pocket the stock boot has.
Old 04-04-2009, 09:45 AM
maggotpez's Avatar
VTEC STICKER > ANY MOD 500HP at least
http://www.bernardiparts.com/Honda-i...C-STICKER.aspx
your welcome............... (late April Fools)
Quick Reply: Any benefit from this bolt on
