Lt-4 Hotcam Instructions
Old 04-02-2009, 01:46 AM
96Formula6spd's Avatar
Default Lt-4 Hotcam Instructions
Hey guys I picked up a lt-4 hot cam a week ago. Anyways the install instructions and break in instructions were not there. Anyone have them or know were I can get them.
Thanks
Old 04-02-2009, 10:22 AM
95z28camaro's Avatar
Check out this very helpful site : http://shbox.com/page/index.html
Here is a direct link to the how-to section(check #6&7) : http://shbox.com/1/how_tos.html
Old 04-02-2009, 10:31 AM
shbox's Avatar
Just for a cam [roller] only, there is no break-in.
Old 04-02-2009, 02:30 PM
RamAir95TA's Avatar
I'm going to assume you bought the other necessary parts too, right? Valve springs, retainers, rockers, etc., and not JUST the cam?
Old 04-02-2009, 03:15 PM
yes i have the whole kit
Old 04-02-2009, 03:18 PM
Looking at it I still need to rev the engine to around 2000 rpm when I start it up or do I not have to do this with this cam
Old 04-02-2009, 03:32 PM
Badazz 97 TA's Avatar
its not necessary to do that, but it does help to get the oil pumped up to the rockers and all the bearings faster. start it up. let it idle for a few minutes to make sure everything is good. Then just hold the rpms steady at 2,000 until you see oil start squirting out.
it shouldnt take too long if the weather is warm
Old 04-02-2009, 03:37 PM
shbox's Avatar
Yes, you should, for oiling purposes.
Old 04-02-2009, 03:55 PM
RamAir95TA's Avatar
Holding the engine RPMs for a minute or two at 2000rpms also helps splash oil onto the camshaft from the crank whipping, in addition to oiling the rockers.
Old 04-02-2009, 03:59 PM
alright sounds good. That is what I have herd of. Making sure that oil gets on to the chamshaft. But looks like you dont have to do it for 20 mins
Old 04-02-2009, 04:54 PM
ss.slp.ls1's Avatar
I would recommend selling the LT4 springs (assuming that's what came with the kit you bought) and getting some better quality springs to ensure that you don't have valve float issues.
Old 04-02-2009, 08:15 PM
trippinholyman's Avatar
i was gonna say throw em away...
Quick Reply: Lt-4 Hotcam Instructions
