View Poll Results: witch one?
Elliot 226/230 .565/.565 111 LSA. - 1900-6200 RPM
14
60.87%
Ai 230 / 238 - .575/.575 - 110 LSA 2300-6400rpm
9
39.13%
Voters: 23. You may not vote on this poll
cam choices
Old 04-03-2009, 10:30 AM
sepno77's Avatar
Default cam choices
witch cam would you go with? why?
Dam i messed up i ment.
Elliot 230/234 .592/.592 111 LSA - 2200-6400 RPM
Choppy idle. Good mid range and top end power. Minimum 2800 stall and 3.42 gears for
F and Y body. Minimum 3200 stall and 4.11 gears for B body. Comparable to Comp 306 cam.
OR
Ai 230 / 238 - .575/.575 - 110 LSA - 2300-6400rpm
This is our largest stock long-block cam for M6 cars. Excellent for rebuilds with 11:1 compression. Lopey idle, good drivability with gears & tuning, and excellent mid-range with peak power at approximately 6300rpm. Properly tuned w/ supporting modifications, M6's typically produce 350-365rwhp SAE corrected
Car is a weekend and strip car, not a DD.
will be getting ported heads and leaving the stock block alone for now. later in the far futur will consider stroker but not now. Right now just getting heads pp, i already got all the supporting mods. looking for 450whp or somewhat close but most of all trying to get some really fast times in the 1/8th
Old 04-03-2009, 10:34 AM
Elliott's94Z's Avatar
I like Lloyds myself simply because that's pretty much the same one I'm running only on a 109 lsa.
Old 04-03-2009, 10:48 AM
DAVE00's Avatar
Not to be a pesimist here but there is a lot you need to answer before you will get good feedback:
1) What are your goals?
2) What supporting mods are you doing (383, ported heads, rr's, cai, etc...)?
3) What are you looking for a good powerful DD or a strip car or a middle of the road both or are you looking for some road racing?
That being said I like lloyd's cam as it has a better range and good topend. However remember if you are staying stock bottom end then you might want to consider beefing it up a little for longevity.
PS: Also remember to fully utilize the power curve of those cams you need to beef up the bottom end as the stock setup ain't gonna last long spinning up past 6K.
Old 04-03-2009, 11:07 AM
DAVE00's Avatar
Remember that with that much lift you will need new springs and pr's. Also, I'm no expert but I doubt you will see 450rwhp with either one of those cams and a stock bottomend plus stock heads with mild pp work. To get those numbers you are gonna need a really good thorough port job by an expert like Lloyd and those heads gotta flow really high for that to happen.
Old 04-03-2009, 11:12 AM
ss.slp.ls1's Avatar
I say go with Ai, but honestly, I think you'll be happy with either, both should make great cam choices.
Old 04-03-2009, 12:26 PM
wrd1972's Avatar
How many posts will it be for this thread to get real ugly.
Old 04-03-2009, 12:44 PM
sepno77's Avatar
were not comparing elliot to ai we are comparing the cam specs
Old 04-03-2009, 12:57 PM
buzz12586's Avatar
Where are you getting your ported heads from? I say get your heads from either AI or Lloyd and the matching cam to go with it.
Old 04-03-2009, 01:20 PM
RamAir95TA's Avatar
I vote both. You will be equally happy with either one. Either way, it will haul ***.
Old 04-03-2009, 01:59 PM
wrd1972's Avatar
Rrrrrrrrright. We will see.
Old 04-03-2009, 02:27 PM
sepno77's Avatar
wow i just got an email from AI and they want to charge me $400 for the cam... thats a lil much so ill be going with the Elliots cam way better bang for the buck. ill buy his cam and have $100 left over for the strip, gas, lunch, dinner and some beer
Old 04-04-2009, 12:35 AM
SoxXpupPeT's Avatar
i love the quality of my LE cam. and at $300 to my door its affordable. youll be happy with either tho.
Old 04-04-2009, 08:49 AM
rickreeves1's Avatar
LE custom cam here for $300.
226/234 565/565 109LSA
Old 04-04-2009, 10:58 AM
buzz12586's Avatar
I know everyone likes to call them custom cams but they really aren't. They each have a selection of cams that they know work well. A custom cam would be if you called up and gave them the specs for your motor and they came up with new cam specs just for your motor.
Old 04-04-2009, 11:11 AM
Good choice of cam
Old 04-04-2009, 11:45 AM
LM97Z's Avatar
Lloyd Elliott !!! Nuff said.
Old 04-04-2009, 12:00 PM
slick1851's Avatar
Anyone care to share numbers if they have either cam
Old 04-05-2009, 07:09 PM
James Montigny's Avatar
Assuming the cam lobes are similar ... see attached.
Note that the longer duration cam makes more power up top
while the lower duration cam has more torque below 5000rpm.
Keeping in mind that 6500rpm is pushing your luck on a stock bottom end.
The 230/238 also has more overlap, which will tend to make it "chop" a little more.
* Illustration only, your HP numbers may vary.
Old 04-05-2009, 08:27 PM
wrd1972's Avatar
Is this real or theoretical dyno numbers?
Old 04-05-2009, 08:39 PM
Dyno sim.
I don't have those cams, or spare cars to put them in and dyno at the moment.
The goal being to provide an idea of what the power curve would look like based on the limited information provided.
Quick Reply: cam choices
