would u cam a 190k z28?
im thinkin about camming the z28 i got a couple months ago..its got a 190k miles... would it be safe or is that a no? IF not ill just wait till i drop the lsx into it..
if compression is solid in all cylinders and she runs well i dont see why not.
would i spray it with nitrous probably not, but i would put a cam in a 200k mile LT1 with little wory as long as it runs well now.
no way. The heads would need rebuilt for sure, comprssion test wont tell you if you need valve seals. If you throw a cam in it will take the seals out and you will burn oil like a mother. And if you rebuild the heads the botom end should really be looked at too.
What you need to do is just get some longtube headers, summitracing.com has pacesetter lt's starting at like 380 and the ory for about 150, a cold air intake, and maby a pcm tune (madz28.com). That will wake her up real good.
yea im planning on changing all the seals , springs , all the goods. if i do is it still worth putting it in? or should i just wait and drop the lsx when it blows?
If you do decide to keep the LT, as long as your oil pressure is still good and you aren't getting blow by, I'd do it. Worst case senario it blows up (spins a bearing) then you through in your LS motor and sell the LT cam.
