duals or y w/ a bullet which has most power?
Old 04-08-2009, 01:21 AM
93 black t/a's Avatar
Default duals or y w/ a bullet which has most power?
Ok i know this question has been asked a million times, but due to the new search not finding my answer, i'll ask it again. Which exhaust setup makes the most power, a off road y with a bullet or true duals? Sound does not concern me. I want the most power.
Old 04-08-2009, 01:23 AM
ss.slp.ls1's Avatar
True duals with a x-pipe would make the most power, and sound the best too. But it will be loud!
Old 04-08-2009, 01:25 AM
Formula350's Avatar
Depends on the pipe sizes for each.
Old 04-08-2009, 01:31 AM
3 inch would be the piping size
Old 04-08-2009, 01:01 PM
StealthFormula's Avatar
In that case the X-Pipe will definetly be better. 2.5" or 3" TD's are a nice step up from a 3" Y-Pipe.
I'm no exhaust expert but I have always heard that the X scavenges really well and acts as a vacuum so to speak by pulling the exhaust out of the cylinders better than a Y or H.
Old 04-08-2009, 01:43 PM
xxxtreme36's Avatar
also depends on what your setup would be, i think tru duals with forced induction. Just my .02
Old 04-08-2009, 01:45 PM
ss.slp.ls1's Avatar
Can you elaborate?
Old 04-08-2009, 02:06 PM
xxxtreme36's Avatar
if your running a supercharger per say.....which i am, the more air your forcing into the engine, the easier you want it to come out of the exhaust. I.E......better flowing heads and larger free flowing exahust
Old 04-08-2009, 02:07 PM
AChotrod's Avatar
TDs with x-pipe is best, Ive heard from a ton of people TDs with H-pipe sounds the best. My car is loud as hell but I love it!!!
After looking at the OPs sig 2.5" pipes would be fine unless he did a ton of other HP mods
Old 04-08-2009, 02:19 PM
ss.slp.ls1's Avatar
That applies to every application, not just FI...
Old 04-08-2009, 10:59 PM
Sorry should've said a little more on the setup. 355 11.7 to 1 compression, LE2 h/c with port matched intake, and full bolt ons. Its a 6 spd car.
Old 04-08-2009, 11:49 PM
myltwon's Avatar
The most common question is 2.5″ or 3″ true duals, and here is your answer.
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
as for 3" y dumped vs 3" TD, the TD setup will make more power and sound better, not sure on volume since one will have 2 mufflers/bullets vs 1 muffler/bullet but also on the other hand 1 is 2 3" pipes vs 1 3" pipe.
for a heads/cam car 2.5" would be my choice, it will support the mods, have more liveable volume, better tone (IMO), cost loss, and have better clearance.
Quick Reply: duals or y w/ a bullet which has most power?
