Question about Oil level in my 383
I have a forged 383 LT4. Usually these engines take 5-1/2 quarts of oil, well we changed the oil b/c we are still breaking the engine in and added 4 quarts and on the dip stick its reading about a quarter of a inch over the normal oil range? The dip stick has not been cut that we know of. I'm not sure why the reading is off and no we have not been running the engine on 4 quarts of oil. I just don't get why the stick is reading soooo high?
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
well i would throw in 5 quarts anyways. i had that problem before. my dipstick read wrong. but i just threwn in 5 qts. cause thats what i knew was what my SBC used. just my .02
+1 - Even with a stroker and the stock pan the crank or rods do not sit in the oil - can you say whipped cream if they did!!! I never go by my dipstick anymore as my canton pan is deeper then it reads. If you drained it then measure out how much came out - fill the old quart bottles - but go with your gut and top it off with the 5th qt and then check it again after it warms up.
Ok tomorrow we will start it and let then let it sit. Thanks for the advice I'll let you know how it goes! Hubby just told me he put the filter on empty and didn't start it.
oil filter is full and it's still reading high after running for about 30 sec and shut down. I usually put about 5 quarts of oil in it depending on how it reads. i'm stumped.
Well well upon further investigation looks like the Oil pan itself is bent. Looks like some dumb **** tried to jack up on the oil pan possibly the person that did my engine build/ install. I'm not about blaming or complanin at this point. I'm just ordering a new oil pan and getting the **** fixed and callin it a day. Guess it's a good thing i got a aftermarket K-member installed while the engine was being built. Might make the job a lil easier.
Thanks all for your help. I feel like a dumbass that I didn't notice that sooner.
If the bottom of the pan is smashed in that far due to jacking after the build....it most likely bottomed out on the oil pick up....confirm it is not bent or if welded on did not crack the weld
also if the windage tray is not on...put it on. Many 383 builds don't because of clearance issues...which are EASILY solved by putting in a washer (1/8") between main stud bolt and windage tray. Miloden also makes extended stud bolts or you can use your stock ones
