wheel specs
Old 04-09-2009, 12:57 PM
Formula934's Avatar
Default wheel specs
Hey guys im looking at going with eagle 211's. Not really sure which ones to go with. Summit comes up with 2 different rims for 17X9.5. The difference is in the backspacing. Can someone point me in the right direction here. 4.50 or 5.50 for backspacing? FYI-I plan on going 285 all around. Thanks.http://store.summitracing.com/egnsea...0&autoview=sku
Old 04-09-2009, 12:58 PM
ss.slp.ls1's Avatar
Why not a 10.5-11" rim and 315 tire in the rear?
Old 04-09-2009, 01:00 PM
Formula934's Avatar
Lol. It has crossed my mind but ive decided on the 285's.
Old 04-09-2009, 01:01 PM
ss.slp.ls1's Avatar
What made you come to that conclusion?
Old 04-09-2009, 01:05 PM
Formula934's Avatar
More rubber=More Money
Also, the 315 is a bit too big for my liking.
ss.slp.ls1's Avatar
Money yes, liking...
11" in the rear looks SICK!!!
Old 04-09-2009, 01:19 PM
Formula934's Avatar
well remember Im stepping up from 245's. So i think 285 is a good compromise. You must know that my 396 just put out 567 hp on motor with a M6. So, i will be roasting the tires off regularly. Im gonna stick with the 285s.
Old 04-09-2009, 01:22 PM
ss.slp.ls1's Avatar
You got to pay to play man.
Old 04-09-2009, 01:28 PM
marc97taws6's Avatar
Hmm, makes the 315's sound even more plausible if you are putting down that much power IMO
Old 04-09-2009, 01:33 PM
Formula934's Avatar
Its not necessarily the size of the tire here but the compound, I could easily go through 2 sets of tires in the rear this season. I would rather sacrifice the extra width in the back for a better compound tire. If money was no object, its a different story. To stay on point, this isnt a debate I just wanna know the correct backspacing from someone who really knows. Thanks.
Old 04-09-2009, 05:08 PM
White Lightning's Avatar
i dont think either will work, cuz with a ten inch wheel u need 7 bs, so i just dont see these fitting without sticking out at all
Old 04-10-2009, 06:43 PM
Formula934's Avatar
I dont mind if they stick out a little bit, I just want to know if they will be compatible with 285's. Also, will 4.5 backspacing stick out more or less than 5.5. Ultimately, will these fit in the wheel well?
Old 04-11-2009, 03:11 AM
Wicked94Z's Avatar
no they wont fit
Old 04-11-2009, 07:49 AM
the less the backspacing the more they will stick out, take a tape measure and measure 4.5 inches from the rotor mounting surface, then add another 5 to that thats where they will sit, waaaaayyy out there
Old 04-11-2009, 08:51 AM
spaz1's Avatar
Yea they will stick out probably around 1. " but you only have to measure 4" out from the mounting surface.You want a wheel with about 3" left over after you subtract the back spacing. These cars need positive offset.
Quick Reply: wheel specs
