Which Fuel Injectors?
How do I tell what fuel injectors I have on my car? They look stock but there is electrical tape on all the wires leading to the injectors like they have been rigged or something it was like that when I bought my car. I am going to get a mail order tune and need to know which injectors i have. Is there usually a serial number on them or something?
The number though should be on the side of the plugin there (on the injector, not the car's wiring harness).
Another good likeness, BUT NOT what came in ours (these are SMP made).
If they look anything other, then they're not a factory GM injector. Mind you, if they came out of a 3800 Supercharged, they'd still look like that but NOT be 24#. That's where the number on the side of the plugin comes in. Pt# 17124248 = 94-97 LT1 24# injector (93 uses 22# and a different number).
yes they look the the one in the first pic. So I guess they are stock 24# injectors. I wonder what all that damn electrical tape was for? I'll have to take it off and see exactly what I have.
Thanks
Thanks
It could be bad, or it could just be to cover the wires up. Lets hope for the latter >_> If it's not, make sure you solder them! Also I recommend shrink tube (heat shrink) over the solder joints instead of electrical taping them again
