tunercats help
tunercats help
i just got my cam heads and headers on, and i was wondering if anyone could help me with getting the tune close enough to drive to the dyno.anyone care to post or pm me a screen shot of there timing and ect tables so i can fix my tune close enough to drive?ive used tunercats a couple times, but im not that good at it.i know i need a higher rev limiter, more timing esp. down low,but what else do i need to do?
I got Tunercats and Datamaster to work by going into control panel, then programs, then Use an older program with this version of windows. The compatibility wizard comes up, pick Tunercats or Datamaster from the list of programs. Pick Windows XP from the first list that comes up. On the next screen check these 3 boxes: Disable visual themes, Disable desktop compositions, Disable dispay scaling. On the next screen check run the program as administator.
Tunercats, Datamaster and Wideband Commander work now using this method.
I hope this helps you.
