another tunercat question
Old 04-10-2009, 02:36 PM
PedaltoMetal's Avatar
Default another tunercat question
Anybody know if Tunercat can disable the codes P0751, and P0757 after installing a high stall converter.
Old 04-10-2009, 02:38 PM
ss.slp.ls1's Avatar
It should be able to tune out any code. Hopefully you installed a nice tranny cooler too.
Old 04-10-2009, 04:30 PM
shbox's Avatar
P0751 is for a 1-2 solenoid problem (something that may need fixing) and P0757 I don't even find.
Old 04-10-2009, 05:53 PM
^^ Is this THE Mr. Shbox? Your website has been a lot of help to me. Hats off to ya.
Maybe I have the other code wrong I will do some digging and see what it's supposed to be. Frank with Performabuilt was talking about how high stall converters throw certain codes and you need to have the test for them disabled in a tune.
Old 04-10-2009, 05:58 PM
ss.slp.ls1's Avatar
The one and only.
Old 04-10-2009, 06:30 PM
shbox's Avatar
Guilty as charged.
Frank may well know, but I didn't think that OBD-II suffered from high stall issues like OBD-I.
Old 04-10-2009, 09:54 PM
It is a OBD-I....with a OBD-II connector. It's a 1995.
Old 04-10-2009, 10:08 PM
shbox's Avatar
Then how are you gettting Pxxxx trouble codes? Those are OBD-II codes. You have an OBD-I computer, if you did not convert it.
There are ways to get around stall problems with OBD-I. Most tuners now know how to do it. Some explanations have been made over at Camaroz28.com in the past.
Old 04-11-2009, 12:39 AM
It's not showing those codes. That's what I was told it would do after some time. I was shopping different tuner programs and just wanted to make sure the one I was considering could do what I've been told I need to do. make sense?
Old 04-11-2009, 08:51 AM
shbox's Avatar
Tuning programs can take car of high stall issues for OBD-I. It is a matter of making some adjustments to parameters, though-not just turning off trouble codes. If you are going to do it yourself, you are going to have to do some reading. I've read some of the stuff before, but didn't pay strict attention, since I don't have those issues (some people refer to one of them as "stall wall" [when it won't shift]).
Quick Reply: another tunercat question
