So any experince on lose rockers? :)
Just pulled the valve covers off and they dont smell to nice. I tugged the push rods and some are definitely lose! It makes a little ticking sound. Also removed the driver side spark plugs, i took a look at the passenger side and ehh looks hard to RR.
Well has anyone done any of this?
to where when you pull up and down on the push rod it clicks...imagine that at 2500 rpm..As i read they arent suppose to have any slack under my own strength
Village Troll
Are you hearing any distinct tapping while the engine is running?
I had a loose rocker a while back and it was very noticeable especially at around 1000-1500rpms (any higher and it started to get drowned out by the exhaust). You could hear it inside the car as long as the radio/ac was off. It made a very distinct tapping sound, kinda like if you had a metal pan and were tapping on it with a coin or something similar. Very noticeable and would trace the RPMs. I narrowed it down to which cylinder was loose by having the car running and taking a really long screwdriver and placing it on top of the valve cover bolts (with valvecovers still on the car) and putting my ear on the handle of the screwdriver. The bolt that had the loudest ticking was where the loose rocker was located. Once I narrowed it down to which head then you could move the screwdriver a little left and right off the bolt and narrow it down to 2 cylinders. After that you'll have to pull the cover off like everyone is saying above to figure out the exact rocker(s) that are loose.
