Replacing negative battery cable
Old 04-13-2009, 12:22 AM
transamws6_97's Avatar
Default Replacing negative battery cable
how hard is this? i have stupid cheap *** closed end wrenches here at school and it stripped the **** out of the nut on the negative battery cable.
Old 04-13-2009, 01:16 AM
fergymoto's Avatar
You shouldn't need to replace the cable, just the bolt.
Old 04-13-2009, 01:18 AM
hitmanws6's Avatar
+1 any parts store will have them.
Old 04-13-2009, 02:15 AM
bdsbirdman's Avatar
You could also look at a stereo shop. They usually sell post adapters that use a slightly lager bolt head that makes them easier to work with imo.
Old 04-13-2009, 12:20 PM
James Montigny's Avatar
Got a set of 18mm ones with my Racetronix kit
They're a lot easier to get a grip on and resist stripping.
Remember to always install positive first, then ground.
That way you don't risk shorting the positive against the AC line LOL
Quick Reply: Replacing negative battery cable
