timing chain lt1
Restricted User
timing chain lt1
http://store.summitracing.com/partde...rt=SUM-G6601-B
can anyone tell me if this timing chain will work since i already have an electric water pump on my 97 trans am
Do you have a vented opti??? You need this P/N: LUN-93094 if your's is not vented because of the gearing in the middle of cam sprocket. It actually turns the opti: the waterpump is driven off a different pin above the timing chainsetup! Hope this helps
It's not a big deal, you just have to clearance it some with a grinder. You could install your double roller, mark the inside of the cover with a felt tip marker, put the cover on with the old gasket and a couple bolts, rotate the engine, remove cover and clearance wherever the chain wiped away some ink. It might take a few cycles, but you'll get it.
