freee mods?
TB bypass is one. Some say de-screening the MAF helps, mine is still screened because I have the SS intake and I need it to flatten out the incoming air so that the MAF reads correctly. 160* thermostat helps a little, esp when you reprogram your fans. LS1 drive shaft frees up some rotational mass, not to mention it gets rid of the vibe. I heard that making sure the spark plug arc arm or whatever you call it is not pointed towards the intake valve is worth 1 avg hp, lol. Not sure what else.
