lt4 hot cam with 1.7 rockers
Restricted User
will the lt4 hotcam be to radical for my car with 1.7 rockers on it. i have a 97 lt1 trans am with all the bolt ons but i still have the stock heads. the cam specs out at 218/228 .557/.557 112 lobe seperration.
Nope, .525" with 1.6's for both intake and exhaust. As long as you upgraded from the LT4 valve springs it should work out well for you giving you up to 10rwhp more. The 1.7's will also give you around 2* more duration also.
scorpion righT? pt num 1026, over on camaross.com i found this thread about a guy trying to run bbc 1.7 and someone replied they were running scorp 1.7 aforementioned http://web.camaross.com/forums/showthread.php?t=670934
http://scorpionperformance.com/newsi...?category_id=1
Restricted User
had that same setup on my car lt4 hot cam w/ scorpion 1.7 rr's i would constantly pull cc306 and gm847 cars no problem and i had stock heads. never dyno'd it or ran it at the track w/ that setup but it sure did perform great on the street. make sure you get springs that will support the gross lift.
Also if you are running on unported factory heads you won't see much if any of a gain by increasing lift more than the 1.6's would be giving you. Stock heads don't flow well over .550" or so lift, so its kind of a waste of money and puts extra stress on the valvetrain.
hmmm, well I apologize if I've thrown this thread off course from the LT4 cam. I have to ask tho...I'm running ported stock heads with stock valves and 1.6 rockers with the 306...wonder what gains I would see, if any, by going up to the 1.7's.
