acc. bracket
Old 04-15-2009, 04:27 PM
91lt1's Avatar
Default acc. bracket
hey guys quick question. My formula is in the shop and needs an acc. bracket, they got one off a corvette and it didnt fit. I found one off of an impala, will it fit???
Old 04-15-2009, 04:30 PM
96capricemgr's Avatar
The b-body bracket is different too. Believe the positioning of accessories is about the same but the depth from the block is different.
Old 04-15-2009, 04:45 PM
ss.slp.ls1's Avatar
The alt. sits a little higher too. I was able to take the passenger side valve cover off of a Buick Roadmaster without removing the alt. Couldn't do that with my Camaro.
This is the one you want:
http://shbox.com/1/accy_brkt.jpg
Part #:10239875
Elliott's94Z's Avatar
I've got a spare one I can sell you if interested
Old 04-15-2009, 07:55 PM
91lt1's Avatar
damn so i guess i cant use it at all huh
Old 04-15-2009, 08:34 PM
91lt1's Avatar
i actually read on a bbody forum that the biggest problem is that the a.c compressor will hit the crossmember, i deleted my a.c, so will i be able to use the bbody bracket now with little modification
Old 04-15-2009, 08:48 PM
91lt1's Avatar
i know someone has to have done it before, im in a bigggg predicament
Quick Reply: acc. bracket
