Best sounding bullet style muffler??
Old 04-16-2009, 10:21 PM
Bad_tx_Z28's Avatar
Default Best sounding bullet style muffler??
Hey fellas, im thinking about changing up my exhaust to a true dual system with a x-pipe and bullet style muffler. What do you guys think is the best sounding bullet mufffler? Also what kind of ground clearence issues are you guys running into? thanks!
Old 04-16-2009, 10:38 PM
hitmanws6's Avatar
you will hear many different answers. borla, dynomax, spintech, magnaflow, flowmaster, summit, everyone has their own opinion. most guys will tell you to go to ls1sounds or youtube so be ready for that
Old 04-16-2009, 10:45 PM
Bad_tx_Z28's Avatar
yeah, i figured that much. But anything will help. I also looking for something with decent ground clearance.
Old 04-16-2009, 10:48 PM
IronOutlaw's Avatar
I ran moroso spiral flows for a while. They sounded good at WOT throttle but I switched to flowmaster 1 chambers for better ground clearence and a lot better cruising tone.
Old 04-16-2009, 11:42 PM
za355tx's Avatar
Well if money is not a problem then the decision gets harder. The Borla XR-1's sound great but are like $150 a piece. I really like the way the sweet thunder mufflers sound but I ended up buying the Dynomax ultra flo bullets. $42 a piece and they sound mean.
Old 04-16-2009, 11:44 PM
brokenbird's Avatar
pro flow twisters
Old 04-16-2009, 11:56 PM
myltwon's Avatar
everything else sounds the same to me personally
Old 04-17-2009, 09:41 AM
Bad_tx_Z28's Avatar
i have used the flowmaster 1 chambers before, and i had ground clearence issues with them. But i loved the way they sounded.
Old 04-17-2009, 10:13 AM
Restricted User
juicdta's Avatar
i have true duals and powersticks on my car. here is an idle clip for ya. they are actually pretty quiet when your driving around, don't get me wrong it is louder than a regular cat-back but not obnoxious. but when you rail on it man it sounds great! imo of course.
Old 04-17-2009, 12:54 PM
Bad_tx_Z28's Avatar
what do you guys think about this?
http://store.summitracing.com/partde...part=MPE-10416
Old 04-17-2009, 01:17 PM
Ferg95 T/A's Avatar
ok here is my 2 cents. My bro has an 02 SS camaro. He has a true dual set- up with an h-pipe. Also LT's. He is running the magnaflow mufflers. And they sound AWESOME...It is loud but sounds great. His ground clearance sucks...bc the shop ran the pipe under the axle...it breaks everytime that you but it on a lift..also the h-pipe hits on railroad tracks and things like that...steep driveways.
Old 04-17-2009, 02:55 PM
Stroked96Bowtie's Avatar
Im running 3in spiral flows, sound great just too loud for my taste on a street car. On a milder setup than mine I imagine they may tone down a bit. Not a fan of bullet style mufflers anyway, but with our cars cant be too choosy. Good luck.
Old 04-17-2009, 06:59 PM
Bad_tx_Z28's Avatar
anyone ever run the magnaflow round case mufflers like i posted above? i have a magnaflow cat-back now and i love it. I just want something louder.
Old 04-17-2009, 07:37 PM
C5042081's Avatar
3" spiral flows here
Old 04-17-2009, 07:39 PM
Verz's Avatar
Ive heard the magnaflows on a LS1 car and it sounds great but im a bit biased towards magnaflow, always had them.
Old 04-17-2009, 07:49 PM
wtomlinson's Avatar
i just had an h-pipe fabbed up with dynomax's dumped right at the rear axle (before the axle). ******** put too big of a kink in the driver's side right after the header, so it's actually lower than my mufflers are. i love the sound at WOT, and at cruising speeds i get a lot of looks
EDIT: forgot to mention, big speed bumps and rough dips are the only problems i have
Attached Thumbnails Best sounding bullet style muffler??-snv10003.jpg   Best sounding bullet style muffler??-snv10002.jpg
Old 04-17-2009, 08:19 PM
Z28_LT1's Avatar
u at stock height?
Old 04-17-2009, 09:50 PM
Bad_tx_Z28's Avatar
why an h-pipe? i thought x-pipes were better for our cars?
Old 04-17-2009, 09:54 PM
1BADBLACKBIRD's Avatar
Here is your final answer: 18" Sweet Thunder Chambered mufllers
http://www.sweet-thunder.com/chamber....html#aluminum
Old 04-17-2009, 10:03 PM
Bad_tx_Z28's Avatar
would those work well with a true dual dumped system?
Quick Reply: Best sounding bullet style muffler??
