WTF... Why is my car so f-ing slow?????
95 T/a
Fully Forged Lt1, Comp Cams CC306 Cam, Comp R 7.2 Chromoly Pushrods, ISKY Adj. Guideplates, Comp Gold 1.6 Aluminum Roller Rockers, Manley Valves, Hell-Fire Piston Rings, Clevite 77 Bearings, ARP Main Studs, ARP Head Bolts, ARP Rod Bolts, Cloyes Dual Roller Timing Chain, Underdrive crank pulley, CSI Electric Water Pump, Custom PCM 4 Less Tune, LT1 Edit Software, LT4 Knock Module, Throttle Body Bypass, MSD 6AL ignition, Accell Pro-Billet Optispark 2 Distributor, MSD Coil, Accell 300+ wires, TR55's, New 02 sensors, K&N Cone Filter, G2 Cold Air Intake, Power Products Polished 58mm Throttle Body, Vortech Polished Elbow, Air Foil, JETHOT Hooker Super-Comp Headers, 3" True Duals, Dual Twister Race Mufflers, Jennings Engineering Racing Viper T56, Fidenza Aluminum Flywheel, Spec Stage 3+ Clutch, Braided Steel Clutch Line, Strange 3:73 Gears, Moser 12, Black Powdercoated ZR1 Rims 17x9 Fronts W/ 275/40/17 Fuzion ZRi's, Rears 17x11 315/35/17 Nitto 555r Drag Radials, Energy Suspension Transmission Mount, Motor Mounts, Sway Bar Links, Sway Bar Brackets, Hotchkis Sway Bars, Lower Control Arm Relocation Brackets.
I ran a 12.9..... WTF... 2.5 60ft sucks but STILL!!! any ideas???
Are the stock heads really holding back that much?
Maybe it not tuned? i bought the car under the impression it was.
help?
help?
Yep that car should be running better, how many times have you taken it down the track? That 60ft is horrible, looks like you spun the whole way there. Spinning isnt winning!
Could just be seat time...
95 T/a
help?
help?
Yea, get that 60' down to a 1.8-1.9 and your running low 12's. You didn't list your trap speed, that what'll really tell if you making good power. You'll never get a decent ET with a short time like that, you can approxmiate .1 in 60' is worth .2 at the end of the track. So for you, drop .5 off your 60', you'll easily run low 12's. I bet you trapped pretty high, right?
Either the suspension needs some serious attention, or you need some more seat time. The driver mod can really do things for an ET, especially in an M6 car.
MPH was 109 i believe.... and this is my 5th track car. im not a professional by anymeans, but i can drive the **** out of this car!... it spins extremely easy so i usually feather the clutch.... I HAVE HORRIBLE wheel hop tho..... i just ordered some LCA's and PHB
Add adj. shocks to that list
